Question about Alpine Air XL-15 Air Purifier
Living Air XL- fan works and green light is on but not the red light. What does this mean?
5 Suggested Answers
  • 16 Answers
SOURCE: Living Air XL (no smell)
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
Posted on Mar 29, 2008
namizhka
  • 148 Answers
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
Posted on Sep 25, 2008
  • 8 Answers
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Posted on Dec 25, 2009
JSEhandyman
  • 368 Answers
SOURCE: do not know what to do when the service required light is on on a Alpine LIVING AIR XL15 IONIC AIR PURIFIER OZONE XL 15. How do I service it?
Hi JoAnn,
Alpine purifiers need periodic cleaning, as dust and dirt from air moving through the unit is electrostatically deposited on internal components; enough build-up can cause short-circuits and diminished peformance. The ozone-discharge plates need to be cleaned monthly, and the inside wiped down at that time. The lint trapscreen on the back also needs to be cleaned (I use hot water in my kitchen sink with the spray-nozzle). I recommend an old toothbrush dipped in household ammonia for scrubbing the plates, and an old sock dampened with ammonia for wiping the inside spaces. The ammonia fumes can be unpleasant, so if you can do this outside or in garage, do so. Also, rinse the plates thoroughly to remove any ammonia residue. Just make sure the discharge plates are COMPLETELY BONE-DRY before putting them back in, otherwise, you risk shorts, and potential damage to the plate. Use the toothbrush without the ammonia (preferably dry) to dust-off the sensor in back that triggers the "service required" light. Iif it's like the ones I've worked-on, it should be connected to another light inside, but I recommend checking your owners manual to help identify the location and description of the sensor.
About once a year, a thorough cleaning (using a brush to get the accumulated gunk out of the nooks and crannies) is recommended). This involves disconnecting the fan leads and (if so-equipped) the needle-point ionier after removing the four screws through the bottome holding the chassis in-place. If you're not comfortable working with wiring and spade-terminals, you may want to use a keyboard vaccuum brush (long-necked tube with a brush on the end available in office-supply stores and the like) to reach in instead.
If this helps, please rate me... thanks!
Jon
Posted on Nov 28, 2011
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
I have the living air xl15 its not working properly, I cant smell ozone no buzzing sound no uv light no green led coming on. I guess the only thing working is the fan. I don't have a manual and it blows my...
I have an extra user manual for the alpine. You have to clean the plates at least once a month to get maximum performance. Get back to me at nick61@telus.net for the manual. Also the ion emitter sometimes needs to be replaced. I use one of mine in my FIR sauna. It seems to be OK at those high temps. 50*-60* C..so far.
Jul 29, 2010 | Alpine Air XL-15 Air Purifier
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Have a Living Air XL15 > everything works motor, fan, BUT .....
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Apr 26, 2009 | Ecoquest Living Air Classic Air Purifier
Sep 25, 2008 | Alpine Air XL-15 Air Purifier
No Ozone
Mine has a switch lower right hand side that will stop the ozone.
Aug 31, 2008 | Ecoquest Living Air Classic Air Purifier
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
~~~creekkid~~~
Dec 19, 2007 | Alpine Air XL-15 Air Purifier
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Oct 26, 2007 | Ecoquest Living Air Classic Air Purifier
Alpine Air XL-15 Air Purifier Logo
42 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
