I have a WC 7120 copier that has an error code 10-338 and the fuser has already been replaced any ideas ?
SOURCE: Error code E000 on a canon imageclass D761
in service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
Posted on Jun 20, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
SOURCE: CL7000 Replace fuser unit type G error
Run SP7-804-9
If you don't know how, or what that is, then you'd better call a service depot.
I will not post or discuss service mode procedures with end users, because you can create a great deal of problems if you're unsure what you are doing. (No offence)
Posted on Jun 17, 2009
SOURCE: Ricoh Afico 2075 sc551 error code. the thermistors
Press total clear (yellow key) , 107 and press and hold the clear stop key (orange key) more than 3 seconds, shut off and on the copy.
Good luck.
Posted on Sep 14, 2009
Xerox wc 5225 error code 062-345.How do I fix?
That is a fuser overheat code suggest you have a techintion repair or replace the fuser
May 16, 2016 | Xerox Office Equipment & Supplies
The error 010-311 appeared. i reseated the fuser unit several times. no success. any ideas?
Hi Anonymous,
If you have a spare Fuser Unit I would suspect you install that and try it.
Have you had a jam in the fuser in the past in which case check the paper sensors are working correctly by activating them with a sliver of paper.
I have known the exit sensor to be jammed and only when you remove the exit transfer unit to the finisher will it be obvious.
If that is a but daunting then you might need to call in Xerox.
Good Luck.
Jun 15, 2015 | Xerox WorkCentre 7120/P Color Advanced...
Xerox 7120 error code 093-320 reset
bonjour j'ai un code erreur sur ma xerox workcenter 7125 je trouve pas de solution si qlq px m'aide merci d'avance code 093-320
Feb 05, 2014 | Xerox DocuColor 240 All-In-One Laser...
7120 copier. Why is there a recurrent 'replace fuser' message?
The fuser's page count has been depleted. At 100K prints the machine declares the Replace Fuser message because it is almost worn out.
May 11, 2012 | Xerox Office Equipment & Supplies
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
Hp Cp6015 printer has 50.7 Error code fuser has already been replaced
this error could be caused by the new replacement fuser or your DC controller board. I would return the fuser that you just put in for another first. And if the issue is still there then try a new DC controller board.
Jun 30, 2010 | HP LaserJet CP6015dn Printer
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
21 people viewed this question
k24674
