Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Is FP on friedrich air and heat unit for freeze protector
My friedrich air and heat unit is on a glassed in porch and the FP was showing this morning ... it got under freezing last night
4 Suggested Answers
  • 26 Answers
SOURCE: outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Posted on Nov 25, 2008
  • 26 Answers
SOURCE: Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
Posted on Jan 24, 2010
  • 183 Answers
SOURCE: My heat &air inside wall unit is blowing on
The only way to solve this problem is to replace the control board.
Posted on Feb 13, 2011
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Just changed blower motor in friedrich vpak unit still wont blow heat
that would be a problem with switch, heating element or fusible link
Dec 07, 2013 | Friedrich VEA09K34 Packaged Units,electric...
My Friedrich A/C is turning on and off by itself, can you help me?
when the room reaches the set temperature the unit is made to cut off until heating or cooling is needed again, this is the units way of not cooling or heating too much.
May 03, 2011 | Friedrich Heating & Cooling
Sir I have a LG terminal airconditionewr/heatpump unit and when i woke up this morning the unit was on with a digital code FP on the screen. can you tell me what this means.
FP- Freeze protection engaged. Check temp setting not more than 5 degree of your room temp.
Check gas pressure. Due to low pressure also freezing will be there. Check and rectify it.
Jan 14, 2011 | LG Heating & Cooling
Unit shows a code fp. What does this mean?
CODE= FP
STATUS = Freeze Protection Engaged. The room temperature measured by the wirelessremote thermostat or indoor ambient thermistor active sensor falls below 40°F.
SUGGESTED ACTION = No Action required. This setting will disengage when theroom temperature rises above 43°F
Is sit helpful?
Dec 20, 2010 | Amana PTH123B25AJ Heat Pump Air...
Its 15 degrees outside and my amana unit is off. every so often it kicks on by itself and runs for about 10 seconds then shuts off again. while it is running the control panel flashes FP, what is it trying...
I was wondering the same thing about our unit until I found the specs online and read that it has freeze protection. When the temp goes below 40 degrees, the fan comes on to prevent damage to the unit.
Dec 23, 2009 | Amana PTH123B25AJ Heat Pump Air...
LG Air Conditioner/Heat Unit spits cold air
I believe the "FP" probably stands for Freeze Protection and it's there to prevent your outside coil from freezing up and causing your head pressure to drop. To do this, it briefly has to reverse the cycle from heating to cooling. This is normal in a heat pump.
Feb 17, 2009 | LG Electronic Window Air Conditioner
Service code FP
I know some manufacturer's use the code FP for Freeze Protection.
Jan 25, 2009 | Amana PTH123B25AJ Heat Pump Air...
Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
42 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
