Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
I have a northstar 5500 with a B/S engine it runs for about 4/5 min then backfires and stops
New gas and filters longest it has run was one time 45 min
4 Suggested Answers
  • 384 Answers
SOURCE: Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Posted on Jul 01, 2009
deme-tri
  • 90 Answers
SOURCE: New NorthStar generator with Honda GX620 runs only a few seconds.
caborator needs cleaning
Posted on Aug 02, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I am trying to find
I am just closing this out. Asker has manual.
Kelly
Posted on Aug 29, 2011
Start and runs for 3 min then stop
Try running it with a loose fuel cap. If it now runs fine find and clear the vent hole in the cap.
Jan 21, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Kazuma 500 running problem
Look for air leaks on the inlet manifold/carb plate. If any air can leak in here, the motor runs lean and rough. Since you replaced the carby, double check the rubber parts for leaks (may not be obvious off the bike so stretch it a bit) and make sure the gasket to the engine is OK (some bikes use o-rings which shrink over time). Next time you run it, when it starts acting up, reach down and pull/push the carby towards the engine. ANY change in revs or running indicates a leak.
Aug 14, 2017 | Motorcycles
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Seems as though the fuel filter is getting stopped-lgt2554
Remove the gas tank and clean it out, look for signs of water and or dirt in the tank also look for a pinched fuel line between the tank and the carburetor
Sep 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
26 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
