Question about StarTech.com Startech Startech A COST-EFFECTIVE SOLUTION, ICUSB2321X IS IDEAL FOR CONNECTING A SERIAL MODEM, BA Serial Adapter
Need driver for startech icusb2321xwindows 7 - StarTech.com Startech Startech A COST-EFFECTIVE SOLUTION, ICUSB2321X IS IDEAL FOR CONNECTING A SERIAL MODEM, BA Serial Adapter
Can't send fax using win 7
why James, can you be more descriptive as to what is /is not happening...any messages you are getting...the software you are using. The startech.com website has a lot of information regarding the modem, have you checked their FAWs on the device or enqured about support.
I suggest you start there if you have not already done so.
Please can you add much more detail and repost the query for support on this site.
I belive that faxing is possible with your device
Feb 28, 2014 | StarTech.com Startech USB DATA FAX MODEM...
Want to know what cables do I need to connect a second monitor to my pc
You can use a USB video adapter to add a second monitor. I have been using one from Startech and it works great. Go here to check it out. http://www.startech.com/AV/USB-Video-Adapters/
Aug 12, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I need gigaware pci card express drivers for usb 3.0 card
I did a little digging and found that Radio Shack actually stopped carrying the Gigaware card, BUT they have a new card from Startech and guess what it looks almost exactly identical to. Long story short I tried the drivers for the Startech version and it installed without a hitch and detected the card right away.
Here are the drivers I used.
http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-Express-SuperSpeed-USB-3-Card-Adapter~PEXUSB3S2
Jul 26, 2012 | Computers & Internet
Driver for ST1000BT32
Try the StarTech website: http://intrl.startech.com/Networking-IO/Adapter-Cards/10100-1000-Mbps-32-bit-PCI-Gigabit-Ethernet-Card~ST1000BT32
Jul 01, 2012 | StarTech.com (ST1000BT32) (DHST1000BT32)...
Windows 7 64bit not finding drivers
Download and install XP mode as a virtual machine. Which should solve the all too often problem related to no being able to find a WIN 7 or 64bit driver. FREE from Microsoft. I use it and it works great
http://www.microsoft.com/windows/virtual-pc/download.aspx
Selvol
Feb 20, 2012 | Startech com Brand Cable USB2SATAIDE USB...
Need Windows 7 driver
http://www.startech.com/Networking-IO/Adapter-Cards/PCI-Express-10-100-Dual-Profile-Ethernet-Card~PEX100S
download the drivers, use the one that is for windows vista, instead of running the driver installer that comes with the it go to the folder that called WINVISTA then go to a folder called 32 if using 32-bits or 64 if using 64 bits OS, inside that folder you will find 3 files extract then to a place you can remember. then go to control panel, device manager, look for the device that has a yellow icon click on it, click on update drivers, click on browser my computer for driver software, click browse, search for the place where you have extracted the drivers from before select the folder containing the drivers, click next and wait until windows installs the drivers.
usually a 85% of the windows vista drivers will work in windows 7.
Sep 13, 2011 | StarTech.com (PEX100S) Network Adapter
I need a W7 or Vista Driver
You could download the driver from StarTech.com: http://intrl.startech.com/Downloads
just enter the product ID and download for your desired operating system.
Feb 23, 2011 | StarTech.com (USBVIDEOCAP) Video Capture
Starview codes
5Ao1 is KEY 00 = 83 5D 12 B8 96 F6 1F C4 KEY 01 = 6D EA 8E 97 6A AA DA 71 7 10 2009@1705
Oct 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Startech webcam driver needed
hi!
you may download from this link:
http://startech.com/Downloads/
Hope this helps.
Jul 09, 2009 | Computers & Internet
Startech.com IEEE 1394 Firewire Cardbus problem
Remove the card, download and install the latest drivers and firmware for the motherboard BIOS and the pcmcia controller from the laptop manufacturer's site. Uninstall all software and drivers pertaining to the startech card, download the newest set from their site, install the card back.
Aug 17, 2007 | StarTech.com (CBUSB2) Serial Adapter
StarTech.com Startech Startech A COST-EFFECTIVE SOLUTION, ICUSB2321X IS IDEAL FOR CONNECTING A SERIAL MODEM, BA Serial Adapter Logo
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
