Question about Nike Watches
Triax c3 battery
Seems to need a reset after I've replaced the battery, how do I do that?
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: I need a replacement strap
Log in to Nike website and click support button. You should be able to ask them how to obtain the part you are after.
Posted on May 18, 2011
Testimonial: "Thanks"
Nike triax
Tissot 1853 I don't know how to reset the time after I changed battery.Pleas held me
Oct 05, 2013 | Watches
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Nike Triax Fury works after replacing battery, but buttons wont work or change anything!
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Good luck.aa07e646-2c11-45e3-b8fa-b40ec2fd82c2.jpg
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Stop screen flashing on nike trax fury
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
I need a replacement strap for my Nike triax 35 watch but all the watch repairers I;ve been to say I need to order one direct from Nike. Can you help? Thanks
May 18, 2011 | Nike Triax 35 Wrist Watch
Somehow I managed to reset my Nike triax 50 by pressing the watch up against a metal bar when trying to strap myself in on an amusement ride. I've tried setting the time and even switching modes but...
mcdevito75 here, It"s possible that when the watch got pressed up against that bar and your arm you mis--aligned the buttons (inside the watch) used on the watch to reset it. BEST BET, Visit a small watch repair shop in your area and have them take a look at the watch, or, you can use the repair service directory right here ay fixya, bottom of this page, click on repair service directory then watches.
Jun 27, 2010 | Nike Triax 50 WR0083-029
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
81 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Nike Watch Expert? Answer questions, earn points and help others
