Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
How can i replace the water tube from a kitchenaid side by side refrigerator when the filter broke from the bottom
The water tube broke from the bottom and I would like to know how I can pull it out to replace it
    Sergeant:
  • 479 Answers
The filter housing is held by screws from the front and can be pulled from the front but you need to disconnect the water lines to pull it through
Posted on Nov 23, 2013
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
  • 3 Answers
SOURCE: water is dispening to slow
check for proper flow and pressure on water supply line
Posted on Feb 23, 2009
  • 78 Answers
SOURCE: Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Posted on Feb 25, 2009
aborcass
  • 2651 Answers
SOURCE: Beeping or Chirping
probalby not relates, but the beeping is ususally accompanied by an indicator light as to why its blinking, perhaps the door open alarm???
Posted on Mar 28, 2009
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
Water dispenser leaks out bottom of door when I dispense water.
Sounds like a small hole in the plastic water tube inside the door. It is a replaceable part but you may need to remove the freezer door to do that. The old tube should come out the bottom near the hinge area. The new tube is then pushed up inside the same hole. There is usually a plastic conduit in the door for the plastic tube to follow. Here is the part number I found for the new plastic tube.
W10277960 about $42 to $45 depending on part store.
Apr 30, 2015 | KitchenAid Kitchen Aid - KSC23C8EYY...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
How do i turn off the water to the in fridge filter on my kitchenaid side by side? the filter nipple broke off and i need to be creative to get it out.
Look behind the fridge for a valve. If it is not behind the mach. Follow the tube through the floor or into a cabinet.
Feb 24, 2010 | KitchenAid KSCS25FKSS Side by Side...
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
How to remove the Pur water filter from the bottom of a KitchenAid side by side Refrigerator
It is a push-button filter located in the grille at the bottom of the fridge. Simply press the release button to remove and replace the Refrigerator Water Filter Cartridge.
Sep 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
How to change water filter of Kitchenaid refrigerator ksss36fkx00
pull the bottom cover off the lower front, you will see the filter on the left lower side. can get them at walmart ...easy to change
Jul 07, 2009 | KitchenAid Refrigerators
The water dispenser bar on my side by side KitchenAid refrigerator (model #KSRB25FHSS02) has a small plastic tube that allows the water to flow out into your cup. That little plastic tube broke in 1/2 and...
Hi Cranberry,
The part your looking for is #8201537. You can see it here.
Threading it through the door is simple if you know the secret to it. First you need to go to hardware store and get something like this about an inch, inch and a quarter. Take a piece of 1/4" tubing with you to make sure the "all-thread" will screw into the tubing snugly.
Now, screw the all-thread into the spout end of the existing tubing (the one in your fridge right now) about half the length of the all-thread. Then take the tail end of the new tubing and thread it onto the left over stub of all-thread.
Open both doors and remove the bottom grill (it's snapped in place) then close the doors. Below the freezer door hinge, you'll see the tubing coupling. Disconnect it and remove the ferrule for use on your new tubing later. Now at the same time, begin pushing the tubing from the top and pulling it from the bottom.
SG
Mar 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
63 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
