Question about AT&T SB35020 Syn248 Desk Phone
Handset does not work only speaker - AT&T SB35020 Syn248 Desk Phone
My idect twin solo second handset only works through speaker phone
My second set no display on Panasonic Mode KX-TGACM
Dec 21, 2013 | Lands Phones
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
Apr 06, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
Oct 21, 2010 | Panasonic KX-TGA271 Cordless Expansion...
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
Speaker works but handset does not. replaced
Make sure to use a new handset cord as well. Also, make sure the handset is plugged into the handset jack under the phone. The 3102 phone has a headset jack that will not work with the handset. There is also a button mapped by default in the upper right corner that toggles from handset to headset. If the light is on, then it is set for headset and the handset won't work.
Dec 18, 2009 | 3Com NBX 3102 IP Phone
Pan KX-TG3032CS: Handset has dialtone on Speaker, not on Talk. Handset works OK otherwise.
Made phone call on Speaker; worked OK.
(Had to phone the library anyway; good test.)
Took handset apart, determined normal ear speaker was OK.
Disconnected Speaker - never used it anyway.
Switched ear speaker wires to Speaker connection. Soldered connection.
Phone now works fine; just press Speaker rather than Talk.
No parts, no cost, & a working phone. And if there's a problem I can simply reconnect the Speaker & use it that way.
Sep 10, 2009 | Panasonic Lands Phones
DECT 225 - Ring tone etc. no longer works on 1 phone
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Oct 18, 2008 | Philips DECT 2252S Cordless Phone
Problem with Audio on Handset
that mean you handset speaker have problem change the speaker or buy new phone for more happy moment
Sep 13, 2007 | Nokia 6133 Cellular Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
AT&T SB35020 Syn248 Desk Phone Logo
658 people viewed this question
Top AT&T Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Terry
Terry
Are you an AT&T Office Equipment and Supply Expert? Answer questions, earn points and help others
