Open circuit fuse F301
After an incorrect power supply was connected to the Panasonic RF-D1 DAB radio, the fuse F301 seems to have failed. Does anyone know what the rating of this fuse should be and where I can get a replacement from?
  • Anonymous Sep 06, 2008
    I have the same problem and would appreciate any help with finding the replacement fuse
  • barryhursell
    barryhursell Jul 05, 2012
    Hi Freegerbil, Sorry to restore your old thread. I have the same problem and don't think the 30V AC I applied will have helped but it might be the fuse - if only I could get the wretched radio open. I. I've undone the four screws, removed the two knobs and unscrewed the DAB aerial. I can crack it open a the bottom but the top is stuck fast, I would appreciate any advice. Thanks Gnunerd
2 Suggested Answers
SOURCE: Panasonic DAB RF-D1 Radio..
The internal 5v battery is flat
Posted on Sep 04, 2008
My bush Arden dab radio won't turn on?
Could be a defective switch, an open internal fuse, or power supply failure
Jun 29, 2016 | Audio Players & Recorders
DAB radio will not work on 18v 3.0Ah battery but works on power lead. any suggestion please
I would open it up and look for a broken wire in the battery circuit, you could have a fuse in that circuit also.
Aug 30, 2014 | Audio Players & Recorders
F301
Look on back of set and inside for a complete model number---F301 would seem to be a location for a fuse--if so amperage will be marked on board next to it and on the fuse itself.
Jun 11, 2012 | Televison & Video
What does the code p0442,p0456,p0700,p0645,p0481,p0340
CODE PO442 - EVAP SMALL LEAKED DETECTED. CODE PO456 - LEAK IN EVAP SYSTEM DETECTED. POSSIBLE CAUSES / VACUUM HOSE CONNECTIONS OR SWITCHES HAVE COME LOOSE OR MALFUNCTION / EVAP EMISSION SYSTEM HAS A LEAK / EVAP PURGE SOLENOID OPERATION HAS MALFUNCTION / NVLD SWITCH OPERATION HAS MALFUNCTION / CODE PO 700 - AUTOMATIC TRANSMISSION FAULT DETECTED .POSSIBLE CAUSE TRANSMISSION CONTROL MODULE RELATED SENSOR HAS SOLENOID IS DAMAGED OR HAS FAILED.TRANSMISSION CONTROL MODULE FAILED OR POWER CONTROL MODULE HAS FAILED.YOU TAKE VECHICLE TO DEALERSHIP THEY WILL TO SCAN TRANSMISSION. CODE PO645 - AC CLUTCH RELAY CIRCUIT MALFUNCTION . POSSIBLE CAUSE.INTERNALLY FUSED IGNITION SWITCH OUTPUT CIRCUIT IS FAULTY. AC RELAY CLUTCH CONTROL CIRCUIT IS OPEN OR IT IS SHORTED TO GROUND. AC RELAY CLUTCH POWER SUPPLY FUSED IGNITION CIRCUIT IS OPEN. AC RELAY IS DAMAGED OR IT HAS FAILED.PCM HAS FAILED. CODE PO481 - HIGH SPEED NUMBER 2 FAN RELAY CONTROL CIRCUIT. POSSIBLE CAUSE HI FAN RELAY POWER CIRCUIT IS OPEN FROM THE RELAY TO FUSED POWER.HI FAN CONTROL CIRCUIT IS OPEN OR SHORTED TO CHASIS GROUND. FAN RELAYS FAILED. PCM HAS FAILED. CODE PO340 - NO CAMSHAFT POSITION SENSOR CIRCUIT FAILURE. POSSIBLE CAUSE CMP SENSOR CONNECTOR IS DAMAGED OPEN OR IT IS SHORTED. CMP SENSOR SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND OR TO BATTERY VOLTAGE OR 5 VOLT SUPPLY CIRCUIT. CMP SENSOR 5 VOLT SUPPLY CIRCUIT IS OPEN OR SHORTED TO GROND OR TO BATTERY VOLTAGE. CMP SENSOR GROUND CIRCUIT IS OPEN. CKP SENSOR IS DAMAGED OR HAS FAILED.PCM HAS FAILED. SOUND LIKE PROBLEM IS PCM GROUND WIRE BROKEN OR LOOSE OR PCM HAS FAILED.
Nov 16, 2010 | 2004 Dodge Intrepid
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
No picture
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | Computers & Internet
Where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
Aug 07, 2009 | Bose Wave Radio
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
Radio Panasonic RF-4900 - no power
Just spent the afternoon with an RF4900 with a power problem. The set was intermittent. Found on the back of the set where the ac plugs in, there is a switch that is ingaged when the ac plugs into the set. If the ac cord is old it might not be engaging this switch when the cord is plugged into the set. The switch controls ether battery power or ac power.
Mar 20, 2009 | Panasonic Audio Players & Recorders
Aug 31, 2008 | Audio Players & Recorders
97 people viewed this question
 Grubhead
Grubhead
