Question about John Deere 22HP Hydrostatic 42" Riding Mower
Tractor runs fine until you start to climb a grade then it seems like it doesn't want to go
4 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: JD 301 industrial loader tractor Overheating
You may need to do a compression test on the engine to confirm whether or not the head-gasket needs to be replaced,that's where i would start if the thermostat is not the problem and the hydraulics are not loading up.Check for oil in the radiator or anti-freeze in the oil as well as for white smoke out of the exhaust,all are indicators of a bad head-gasket.
Posted on Jul 18, 2010
  • 3911 Answers
SOURCE: Speed of tractor slows when
you need to call a dealer and get a price to replace the transmission. perhaps you can swap yours for a rebuilt tranny. If you are at all mechanical, you can change the transmission yourself in an afternoon, so some cost could be saved on labor.
Posted on Apr 25, 2011
SOURCE: tractor dies
my lx173 quits running after a while and will start back up and run for a while longer and quit again
Posted on Jun 13, 2011
I have a John Deere LTR166 16hp hydrostatic mower it drives fine around the yard un till it has to climb a grade then it just doesn't want to do it. I noticed it over time this past year it seemed to have...
try ck'ng the transaxle oil level some models have a tiny dip stick thats acessed under seat or between rear wheels others just have a sight plug (two pipe plugs that are directly over one another in side of transaxle) ck at wheel axle shafts for oil leakage (so u know where oil went) also ck for tightness of drive belt and clutch spring (in mid center) those last two are a bit tough to reach with mower deck on (you might have to remove it )
Nov 22, 2013 | John Deere Garden
CTH 171 Mower starts and runs fine but lacks power to climb even gentle slopes whether or not it is cutting.
The mover has great vibration as all mowers do. That is why the valves are recommended to be regapped at every 250 hours of running time. If not checked the engine will run although will be reduced in power going up a grade. Eventually it will not start so easily if not serviced soon
Jul 09, 2011 | Husqvarna Garden
Hello, my LGTH2454 has been running fine. It sat for about an hour then I went to start it and the starter engaged on the flywheel but won't turn. I took the starter off and tested it. It seems to...
Sounds to me like the battery hasn't enough charge to turn the engine. Taking the starter off and testing it doesn't require much power as it doesn't have to turn the engine. Check the battery and also that the charging system is charging the battery back up. Alex.
May 20, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Speed of tractor slows when I run for more than 10 minutes. It will not climb a small incline after it gets hot. I can let it cool for a half hour, then it runs fine untill it gets hot ,and eventuall will...
Apr 24, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drives fine on level terrain start up a slight grade it stops,engage brakes nothing tractor goes backwards will not stop.
When you go up a grade do you smell the belt burning (rubber burning smell) when it starts going backwards on you. It could be that the drive belt is not tight enough.
May 05, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Model # 917256563 19.5 hp Craftsman. Ran fine until the front tire fell in a small hole. I heard a poping noise from rear of tractor I lifted the wheel out the hole and now the tractor will only run if I...
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
Aug 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Loss of power in 92 4x4 nissan truck
it seems to me that your air flow meter needs to be replaced.
Jul 07, 2009 | 1992 Nissan Pickup
Craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 22HP Hydrostatic 42" Riding Mower Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
