Question about Conair i-Stubble Electric Razor
Trimmer guide broken - Conair i-Stubble Electric Razor
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
Internal metal cable from flexible shaft is broken 54-4770-4
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 23, 2012 | Garden
Trimmer runs but the head wont turn
It may be that the drive shaft is broken, or not engaged to the engine. Make sure the trimmer attachment is locked all the way onto the shaft coming from the engine. If it still doesn't work, check by seeing if any of the other attachments work when you put them on. If they do, you know the drive shaft in the trimmer attachment is probably broken.
Aug 17, 2011 | Craftsman Convertible 25cc. Gas Line...
Replace broken pull cord on RBC30SESA trimmer
The reason why ryobi tools are cheap is that when they go wrong and they all go wrong they should be chucked away as some times they can cost more to fix than buy new.
Depending on where you live you can contact roybi andthey have a very good service deppartment
Jul 23, 2010 | Ryobi 15" Electric Factory Reconditioned...
Broken Edge Guide
The diameter of the Black&Decker GH400 edge guide is 1/8". I know because I have the same problem and a small piece left from the original. Trying to find a new one is quite the quest.
Apr 22, 2010 | Black & Decker Garden
Pop up trimmer stopped working Remington R830
Make sure you are using the trimmer with the shaving heads on the shaver. With heads removed, the trimmer on the back will not work properly. If thats not the problem, the trimmer is broken or jammed. clen the blades really well with a toothbrush and rubbing alcohol. If they're jammed, this will probably free them up. If that doesnt do it, the trimmer is probably broken and that part is no longer available from Remington. If you really like this model, you can find a replacement at shaveroutlet.com
Jan 10, 2010 | Remington Health & Beauty
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
Aug 31, 2009 | Black & Decker 14" Grass Hog Xp...
Trimmer problem
does the trimmer blade move side to side? there's a fixed comb and a movable comb. the movable comb is much like a hedge trimmer. a cutter moving right next to a fixed guide comb. its supposed to shear off hair with every side to side motion. if its not moving it ain't cutting. it operates off the electromagnet inside the unit. broken linkage will cause the problem.
Aug 18, 2007 | Remington Titanium Microflex R-950...
Conair i-Stubble Electric Razor Logo
44 people viewed this question
Top Conair Electronics - Others Experts
Are you a Conair Electronics - Other Expert? Answer questions, earn points and help others
