Parker tv RC-A27-OT
My tv remote is not working and tv not starting, changed batteries but still not coming on
kitquint
  • 40 Answers
SOURCE: Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Posted on Sep 15, 2008
  • 172 Answers
SOURCE: Samsung TV Remote
Replace it with a Universal Remote with Learning, This way, if the new Universal codes in its Manual don't work for your Samsung, (they most likely will if the new remote is not used older one bought off eBay) then you can Teach it to Learn codes off the working keys on you Samsung.
Sony Learning Remotes are a very good choice, sold at Walmart or eBay. The advantage to a good Universal, is you can also program in all your other audio/video remotes into one remote.
Posted on Aug 24, 2009
SOURCE: Direct TV remote "tv input" button won't work with my Sony TV
I came across this looking for a similar solution for my Samsung TV, and I found the solution on ehow.com. Apparently after you program the remote for your TV you have to hold mute and select again until it flashes twice then put in 960 to make the remote control TV input too. Note you're remote should be in TV mode while you do this. It seems silly that the DirectTV guy wouldn't do this when programming the remote.
Posted on Nov 28, 2009
  • 126 Answers
SOURCE: i just put new batteries
595, 618, 743, 744, 005, 006, 019, 020, 120, 745, 757
here you go enjoy and please vote on this help
thank you
seth
Posted on Dec 03, 2010
gopakumarg43
  • 74617 Answers
SOURCE: remote control amadeus symphony ruwido Rc 21100 doesn't work with my tv, I need codes
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
Posted on Jun 01, 2012
MY PARKER REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
I had a remote stop working and took it in and all they did was remove the batteries over night and then it started working again.
Dec 30, 2014 | Televison & Video
MY TV REMOTE SUDDENLY STOPPED WORKING WHAT COULD BE THE PROBLEM
Reprogram!
HOW TO PROGRAM Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
My Kenwood RC-150 Learning Remote. How do I delete a programmed key
Remove the batteries and let the remote sit idle for a time until retained memory fades. Reinstall the batteries and start over again.
Nov 16, 2013 | Kenwood Remote Control RC-150...
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
RC-261 fails to turn on/off Insignia TV. Remote stopped working (batteries good)
Check the battery contacts inside its battery compartment for any rust or dust accumulated. Clean them well. If this too do not help you, check the remote control for its infrared emission. In some cases, cleaning the remote control may be necessary. If you wish to get more details about how to check, repair and clean a remote control, visit this site. Pull up older posts. One among the post has details.
Mar 24, 2013 | Insignia RC-261
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
Remote compatability
i have a RCA RCR312W universal remote will it work on my JENSEN Model TS2050J 20" TV?
Feb 03, 2009 | Jensen TS2050J 20" TV
Parental lock triggered on previously owned television, need to remove it
When the tv is on press and hold the "Display" button on the remote for at least 3 seconds.
Jan 31, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
