Question about Aluratek ADPF08SF 8" Digital Photo Frame
Turning on and off
Won't come on every time; took it Sat to an event and worked great; today, couldn't get it to come one; brought it home, came on. this is the second one that has done that. Used both remote and back of screen power buttons.
1999 Yamaha 1200 XL won't start only start button lights up
Please repost this in the section for motorcycles.
Jun 11, 2013 | Cars & Trucks
Locks won't work and Windows won't go down brought
Check for a broken wire in the door jam. Other wise I think, You need to research this more, that the Left Front Power Window Switch is actually a door module. I would guess it has either lost power or gone bad.
May 26, 2012 | 1999 Jeep Grand Cherokee
My lg intellowasher won't start
Here's a fix that worked for me today! I couldn't make it turn on for over 24 hours. As a last-ditch effort I put my hairdryer on hot and aimed it at the on/off button. I waited 20 seconds and it turned on! (took about 20 presses of the button). In my mind the heat from the hairdryer is expanding the circuit board so that the things that aren't connecting can connect. Hope this helps!
Mar 31, 2012 | LG Washing Machines
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Murray 42in 14 hp won't start. bat. good ,new cables,new switch,new solenoid,won't even click. HELPIt is a Murray riding mower.The modelno. sticker is gone. I think it was made in 2000.
My best guess is that your seat safety switch is either not being activated or has gotten really out of adjustment
Second guess is that your neutral safety switch on your shifter is out of position
Mar 30, 2010 | Garden
Gps500we sat nav problem
harman kardon gps 500we will not turn on, I am not sure why, its was working fine the day before and the next day I try to turn it on and it would not, I try to reset the satnav, that did not work either, I took it home and try to charge it overnight, that did not help, I suspect the battery because while it did not come on it did not felt warm from charging it overnight, if is the battery where can I get a replacement. I have no warrenty because I brought it 2 years ago.
Jul 24, 2009 | Harman Multimedia Harman Kardon Guide+Play...
1999 GSXR 600 ---> Hesitating and bucking??
Check the tank for water or crud. Also drain the carbs to make sure the floats aren't obstructed.
Apr 29, 2009 | 2006 kawasaki ZX-6R
Ethernet
The internet cable fed to your modem by your ISP if faulty.
Jun 29, 2008 | Computers & Internet
Aluratek ADPF08SF 8" Digital Photo Frame Logo
149 people viewed this question
Top Aluratek Video Cameras Experts
Are you an Aluratek Video Camera Expert? Answer questions, earn points and help others
