Question about Refrigerators
The ice maker in the bottom freezer refrigerator model W10360467A
There may be something frozen up or blocked, as there appears to be no water supply feeding into it. This seemed to have started a couple of weeks ago. The lever is in the proper down position. A child may have bent it-not sure.
catriver
  • 878 Answers
SOURCE: Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
Posted on May 06, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Sea Breeze
    • 4655 Answers
    SOURCE: ice maker flooded top freezer compartment
    It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
    http://servicepartstec.blogspot.com/
    Posted on May 20, 2009
    ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
    Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
    It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
    We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
    Thanks
    Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
    Ice sheet on back of ice maker & in ice bucket
    Happy 20th Birthday Refrigerator. Time to replace.
    Jun 25, 2017 | Whirlpool 21.0 cu. ft. Top Freezer...
    Ice maker stopped working
    Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
    Mar 02, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
    Water Leaking From Under LG LRFD21855 Refrigerator
    yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
    Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
    Ice turning into a solid block in freezer. Samsung Refigerator
    when you look into the freezer where the ice maker is do you see something hanging underneith the ice maker? if you doi that is the sensor. If not contact me and I will walk you thru the steps to correct the problem.
    Jan 30, 2009 | Samsung RS2630WW Side by Side Refrigerator
    Ice maker not working
    You will have to pull the ice maker out, defrost fridge or use a hair drier to defrost all parts in the freezer. then replace ice maker
    Jan 21, 2009 | Sub-Zero 611 / O Bottom Freezer...
    make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
    Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
    Ice maker not making ice. Water disp inside frig disp water.
    the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
    Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
    Refrigerators Logo
    120 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
