Question about Hoover Whole House Bagless Upright, UH71209
Vacum over heated and sut off now it won't turn on
The bristles will not turn when vacume is on and I try to vacume
Alot of those vaccums have a little drive belt on them. You might look for that. Also some string might be caught on the side of the brushes.
Sep 13, 2014 | Vacuums
My built in beam vacum cut off soon after turning it on why?
may have over heated. i'd check for clog in hose before i did anything else
Jan 14, 2013 | Beam Industries 2775 Serenity Plus Central...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My vacum keeps sutting itsself off after a few mins of use. I need to vacum the whole house and dont have tinme for it to cool down every 10 mins
Something is plugged. What you describe sounds like the motors' thermal limiter is opening the circuit to prevent the motor from overheating. You need to open and verify that evey air passageway is clear and the unit has good air flow. I bet you find a blockage, and with one, cleaning ability would be severly diminshed.
Nov 19, 2010 | Dyson DC31 Animal Bagless Handheld...
I bought a Eurika upright vacum (the boss whirlwind lite) it is pretty new, keeps shutting off before i am done vacuming, and the hose doesnt **** very well!!!
your model mite have a divice that turns the motor off if it heats up if so take it to a repair shop and have them look at it
Jan 07, 2009 | Vacuums
Vacuum won"t turn on with the switch
could be the cord, switch or the motor
check them with a ohm meter
Jun 28, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Hoover Whole House Bagless Upright, UH71209 Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
