Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
Fitted new chain will not cut - Worx (16") 3.5 HP Electric Chain Saw - WG303
How to put the chain back on a 16" Poulan electric chain saw
its probably like the gas model. so you remove the 2 nuts holding on the side cover of the blade side, remove the cover and the blade and chain. To fit back, slacken the adjuster screw a little bit, or if fitting a new chain then a fair amount, as you have to be careful that the pin on the adjuster fits into the proper hole on the saw bar, as you fit back on the bar, of which you have already cleaned out the grooves. supporting the bar in the slackest position, fit on the chain, making sure that the cutting edge at the bottom is coming towards the motor. Then slide the bar and chain away from the motor to take up the slack, then fit back the metal guide in the original position, fit cover with the adjuster pin in its hole on the bar, and replace the 2 nuts almost tight but slack enough to use the adjuster to set the chain to cutting position..slightly sagging on the sprocket nose type, or snug on the solid nose type..then tighten the cover 2 nuts firmly but not excessively as that will damage the machine..NB the bar & chain depends on the adjuster, not on the nuts tightness to maintain tension
Jul 14, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Bosch ake 40 will not cut properly
I do not mean this as an insult but since I have seen it before I have to ask if you put the chain on backwards?
Other then that I know that if you hit dirt, even with a new chain, it will dull it quicker then anything else.
Aug 23, 2012 | Bosch AKE 40-19 S Electric Chainsaw
Need to put a new chain on a Husqvara 235 14 inch chain saw?
Check that the chain brake is in disengaged position by
moving the front hand guard towards the front handle.
Remove the bar nuts and remove the clutch cover (chain
brake). Take off the transportation ring.
Fit the bar over the bar bolts. Place the bar in its rearmost
position. Place the chain over the drive sprocket locate it in
the groove on the bar. Begin on the top edge of the bar.
Make sure that the edges of the cutting links are facing
forward on the top edge of the bar.
Fit the clutch cover (chain brake) and locate the chain
adjuster pin in the cut-out in the bar. Check that the drive
links of the chain fit correctly on the drive sprocket and that
the chain is in the groove on the bar. Tighten the bar nuts
finger-tight.
Tension the chain by turning the chain tensioning screw
clockwise using the combination spanner. The chain
should be tensioned until it does not sag from the
underside of the bar.
The chain is correctly tensioned when it does not sag from
the underside of the bar, but can still be turned easily by
hand. Hold up the bar tip and tighten the bar nuts with the
When fitting a new chain, the chain tension has to be
checked frequently until the chain is run-in. Check the
chain tension regularly. A correctly tensioned chain
ensures good cutting performance and long life.
Jun 27, 2011 | Husqvarna Garden
I have just fitted a new chain, but I am getting a very poor cut, would I have fitted the chain the wrong way?
As you run your finger across the top of the bar, from the front to the back, towards the motor that is, the teeth should be pointing forward. Check it out and if they are not, just flip the chain.
Mar 11, 2011 | Garden
I have a 358351610 chain saw and need to find out how to remove the chain
Set the chain brake to off, then remove the fasteners on the right side cover where the chain drives from. This will release the bar which will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting edge of the teeth. Clean everything including the two small oil passages that run from the large holes in the bar out to the chain groove on each edge of the bar. When refitting a new chain, back off on the chain adjustment screw (CCW) a few turns to allow the cover to fit to the bar properly. Fit the chain over the clutch sprocket, then insert the bar to the engine. Work the chain over the bar, then pull the bar outward to tighten the chain. Install the cover and the fasteners finger tight. Make sure the cover fits the bar properly. Tighten the chain adjuster CW so that the chain pulls up to the lower bar edge, but not so tight that you can't turn the chain by hand. Tighten the cover fasteners, then recheck the chain tension. The lower run of chain should be cutting as the chain moves toward the engine. Check the chain oiling by running the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 19, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Need to replace chain on farm boss with 20 inch bar how do i get to sprocket to get old chain off
Release the chain brake. Remove the nuts/bolts that hold the right hand cover over the drive end of the bar. With the cover off, the bar will slide back toward the engine and allow the chain to be removed. Note the direction of the cutting teeth! Clean the side of the engine where the bar fits to, and the small oil passages in the bar drive end that run from the large holes out to the chain groove on each edge. Also clean the entire chain groove. Fit the new chain to the sprocket, then insert the bar and work the chain onto it. Pull out on the bar until the chain fits fairly tight, then fit the cleaned cover over the drive. You may have to change the position of the chain adjustment screw a few turns to allow the adjustment 'tang' to drop into one of the large holes in the bar. Make sure the cover is fully seated, then run the fasteners down finger tight. Turn the chain adjuster screw CW until the chain pulls up to the bottom edge of the bar, but not so tight that you can't turn the chain by hand. Tighten the fasteners fully and recheck chain tension. Start the engine and run the tip of the bar near some cardboard at speed for a moment or two--proper oiling is indicated by a thin line of oil thrown onto the cardboard. Be sure to keep the chain teeth sharp and properly adjust chain tension--don't allow it to droop when cutting. Hope this helps!
Dec 08, 2010 | Stihl MS 290 Chain Saw include 20" 50cm...
Chain broke and the new one wont quite fit how do i adjust the back wheel to make it fit, do I have to loosen the big lug b4 adjusting the screws
The large axle bolt holds the wheel in place. The adjusters are only used for setting the position of the wheel , mainly for chain and sprocket alignment. First remove the cotter pin and loosen the large nut on the axle bolt. Now you can loosen the adjuster bolts and slide the wheel forward. If you have the correct length chain for the sprockets every thing should fit perfectly. When you unhook the old master link do not remove the chain. Hook the new chain to the old chain using the old master link ( do not lock it on) just use it to pull the chain around the front sprocket. This will save you having to take off the front sprocket cover. I usually find it helpful to count the links on the old chain and lay the chains side by side to make sure the new chain does not get cut too short. If the chain is too short , you may have to get another master link and add some chain back in to get the correct length. Hope this helps.
Jul 07, 2010 | Honda CB 100 Motorcycles
How do I fit a new chain on my mountain bike?
you can always get yourself a master link kit for your chain and cut the chain then lay it around the sprockets until the chain overlaps , count the number of links that overlap and leave just enough so you can cut off the excess chain and have enough links to splice the two ends of the chain back together so it will have enough slack to fit back on the sprockets , or you can also just purchase a shorter chain at any bike shop , bring your old chain with you so you can compare how much shorter your chain has to be , hope i was able to help you sincerely glenn mayer , please leave a nice rating if i was of help to you, thanks again for the question
Mar 06, 2009 | Cycling
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
18 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
