Problem for Washing Machines
Generic problem for all Washing Machines
Washing machine wont run or turn off/on.
Hi, my Hotpoint washing machine on/off button is stuck on the ON position. It was blocked and was full of water so some water leaked from the door. Thanks
Solution #1
posted on May 07, 2009
Rank: Guru
Rating: 86%, 17 votes
It leaks
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
- Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
- The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
- Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
- Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
- Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
- Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
- Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Seek advice to max small kitchen in Massachusett.
Wondering if anyone has good result installing...
(More)
Wondering if anyone has good result installing washer machine in uninsulated garage.
Would it workable/risky for pipes to survive our cold new england winters?
If so...is is cost effective? Thanks
who has the best built front load washing machine that is dependable and resonably priced.
Hi, I'm trying to contact the agent that repairs Ariston washing machines in Singapore - would...
(More)
Hi, I'm trying to contact the agent that repairs Ariston washing machines in Singapore - would anybody have this contact? Eileen
Tub is full of water, but will not spin. What is wrong?
code f25 error kenmore elite he5
