Question about Mediasonic ProBox K32-SU3 Black SuperSpeed SATA HDD External Enclosure
How to open this enclosure to install hard drive
    Problem Solver:
  • 3 Answers
Was dropped and now no power light comes on can I fix it
It could be that the hard drive is probably loose and is no longer connected to the enclosure sata controller. You can open the enclosure to see if something came loose. If it did then reconnect the parts and try to power it up. Worse case, you will have to get another enclosure for the hard drive should the enclosure is no longer operable. This is to say there was no damage down to the hard drive. Make sure warranty has expired before voiding warranty by opening enclosure.
Nov 21, 2013 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
Attempting to transfer info on hard drive installed in 2.5sata enclosure to laptop
If you are only transferring data and not installed programs or the complete operating system, just open an explore window each in the storage drive and the target hard drive side-by-side, select all the data you want to transfer, and drag and drop it onto your drive (in whatever folder you want to make). Done in a few minutes.
Oct 10, 2013 | Vantec VT-CX EXT 2.5SATA ENCLOSURE...
Hi! I have Samsung S2 Portable Hard Drive. It was working perfectly fine until suddenly the blue light stopped flashing and the computer can't detect it anymore. Is there any way for me to recover the...
You may need to open the enclosure and install the drive into a new working enclosure, that is assuming that the hard drive itself is not at fault.
Aug 27, 2013 | Computers & Internet
Broken mini usb contection
If your talking about the cable, replace the cable. If your talking about on the external hard drive, either replace the drive if it's under warranty or go buy a new external hard drive enclosure, open the samsung HDD, put the drive in the new enclosure. Opening the enclosure will typically void the warranty.
Dec 23, 2012 | Samsung G2 Portable External HX-MU050DC/...
How to change a pc hardrive
It is actually pretty simple to do. First of all, make sure you have a backup.
1. Open you computer case. You will likely have to open both sides, unless you have a hard drive enclosure, so check your computer manual on how to do so.2. Pull out the power and SATA cables (will be red and thin). You will need them when you install the new hard drive.3. Unscrew the hard drive. If it is in a hard drive enclosure, it will likely be held by thumbscrews. Unscrew the thumbscrews holding the enclosure to the case and then unscrew the hard drive.4. Place the new hard drive into the computer or enclosure and screw in. If in an enclosure, screw the drive into that and then enclosure back into the computer.5. Plug in the cables that you took out of the old hard drive.6. Close the case, install operating system if it was replacing the hard drive that had it, and you should be good to go.
This video should help if you are confused:
Here is a video that will show you how to replace your hard drive:
http://www.youtube.com/watch?v=xN59W-56p3I
Mar 28, 2012 | HP Computers & Internet
1tb LaCie drive turns itself off and on randomly
It probably is about to "die" -- copy all the files from it to your computer, before it does completely quit.
Then, exercise the warranty to get a replacement.
Or, open the enclosure, remove the disk-drive, buy a new, compatible disk-drive, install into the enclosure, to "revive" your external storage device.
Oct 29, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have removed the hard drive from the computer. I just want to recover the data on the hard drive. I have an IDE hard drive enclosure. Do I need to remove the metal plate covering the hard drive before I...
I gather this is a laptop hard drive we are talking about? yes. So If your talking about the plate that is screwed to to the drive to mount it into the laptop & its held on with 2 or 4 screws, then yes but the hard drive itself must not be opened up.
Oct 11, 2010 | Computers & Internet
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
How do I connect laptop hard drive to hard drive enclosure?
open up the hard drive enclosure and hook the cables up the only way they will hook up. close the enclosure up and connect to computer.
Jun 17, 2009 | Ultra -Slim USB2.0 Hard Drive Ext....
Mediasonic ProBox K32-SU3 Black SuperSpeed SATA HDD External Enclosure Logo
445 people viewed this question
Top Mediasonic Computers & Internet Experts
David Payne
David Payne
Are you a Mediasonic Computer and Internet Expert? Answer questions, earn points and help others
