Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water will not shut off and overflows whirlpool mod#lsr7233eqo
4 Suggested Answers
  • 105 Answers
SOURCE: fills up with water and wont stop
Bad Preasure valve comes to mind first and formost it acts like a level sensor balanceing the size indicated for fill.
Posted on Feb 10, 2009
  • 56 Answers
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
Posted on May 07, 2009
SOURCE: What's the capacity for the whirlpool washer LSR7233EQO?
How do I determine the capacity of my washer?
Posted on Sep 07, 2010
Whirlpool LSR8433KQ keeps filling with water and overflows. What can I do?
Pressure switch W10339229 or inlet valve may be stuck. If the water shuts off when you push in the timer knob to stop the machine, then water valve is ok. Try a different water level setting.
Mar 30, 2014 | Whirlpool Washing Machines
Have a fluid master valve--I believe it is a 883B--fills the toilet and appears to shut off but very slowly keeps filling. Never actually shuts off completely..Please Help!!
there are only 2 possibilities; 1 the tank seal is leaking into the bowl and the input valve runs to replace the water lost, or 2, the water inlet valve does not shut off totally and the water continues to flow into the bowl via the overflow tube in the tank.
If the water is running into the overflow tube, adjust / replace the input valve, if the water is not going into the overflow valve, clean / replace the flapper valve at the bottom of the tank.
Please let me know how you make out.
Aug 25, 2011 | Home
Can a brand new top load whirlpool washer model wtw1500vq2 overflow or does ithave automatic shut off?
DEPEND WERE IS THE OVERFLOW IF ITS ON THE DRAIN HOSE ATTACHED ON THE WALL U MAY CHECK THE DRAIN PIPE CAN BE CLOGGED. ANOTHER THING ITS THE WASHER HAVE A WATER LEVER PRESSURE SWITCH PROBABLY BE DAMAGE.
Nov 11, 2010 | Whirlpool Washing Machines
Wate does not shut off
If your saying , when the machine is off , the water keeps running , you need to replace the water mixing valve pt. # 285805 . If your saying , when filling , the water does not cut off , then it could be the water level switch hose came off , which is located behind the control panel , and it just needs slid back on , OR , it could be a bad water level switch ( not likely though ) .
Nov 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Gold dishwasher water overflowing and will not shut off
There should be a dome shaped float switch on the inside bottom of the washer. Make sure it is free to move up and down, or is able to float (possibly cracked or broken).
Jun 28, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Fills up with water and wont stop
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
Washer overlfow
How bad is the water overflow. A little puddle on the floor, or it will fill up to the top and be a waterfall until you shut it off?
Mar 11, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
