Question about Dell Inspiron Internal 56K Modem P7125
Need information for Modem DPN: P7125
I would like to get information and specifications for 0P7125 P7125.
Model number of motherboard installed on dell OptiPlex 745
Look at the old motherboard. There will be a sticker with DPN: followed by a series of letters and numbers. DPN stands for Dell Part Number.
Feb 11, 2015 | Dell Computers & Internet
P7125 modem drivers
Please try this link.
http://www.dell.com/support/drivers/us/en/19/DriverDetails/Product/inspiron-9300?driverId=R104087&osCode=WW1&fileId=2731113016&languageCode=en&categoryId=CM
Nov 23, 2013 | Conexant Dell Inspiron 9300 Modem Module...
Pci bus 2 device 0 function 0
You need to be alot more specific. That doesn't tell me anything usefull. If it is some kind of error, check whatever card (sound video, modem etc) is plugged in to your mainboard and reset it. I really cannot help you without more information.
May 30, 2013 | Acer Aspire Computers & Internet
Hi, just reinstalled window 7 now and mising network driver for dsl connection. how can i installed without CD software. regds
You'll need to go the router manufacturer's website and download the drivers, or check with the ISP you bought the modem from, and download from there.
Without knowing any specifics about your network or modem/router, the best I can do is point you to this excellent website, which has a vast resource of information, tutorials and troubleshooting information to help you solve your networking problems. See here, here, and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 10, 2011 | Computers & Internet
Just got wpn824 and having problrms with pppoe login and pass. Using att dsl ...but that login isn't working
You'll need to set your DSL modem up for "bridge mode". Right now it's acting as a router as well and that's keeping your new router from making the connection. In bridge mode, the modem acts only as a modem to connect to AT&T. Then your router will provide your login information and your computers will connect through it correctly.
You don't give your modem model so I can't give you any specific directions. A Google search for "bridge mode" and your modem's make and model should turn up the information you need. Or you can call AT&T's technical support number and ask them how to configure your modem. (Sometimes these big ISPs aren't too keen on helping you, though. They'd rather supply you with a wireless router/modem at an extra charge.)
Hope this has helped. Thanks for using Fixya!
Feb 15, 2010 | NetGear RangeMax WPN824 Router
Need to connect motorola cable modem to laptop along with pc
ok you will need to ethernet cables
and a phone line
connect the phone line with a filter to ur modem
then connect to both PC and laptop
then you should be able to connect
unless its a new one
then you will need to configure to the specification of ur ISP
more information
please if that dosnt work
* R U trying to connect wireless
* is the modem new
*who is ur ISP
Apr 11, 2009 | Arris SURFboard SB5120 Modem
Cannot fax using epson bx300f
This response is a little late, but it's because you all appear to have something other than an Epson C86, under which your problems are listed! Eoromarts problem is super-generic. It could be due to hundreds of reasons ranging from "because I was in Blackpool at the time" to "my wife had borrowed the modem cable for a washing line". Come on, you need to give a lot more information than that!. McFax - your problem is simply not understandable please be much more specific!.
However, we may be able to help Stretchyd who has provided actual information on his problem. You cannot send faxes by Broadband. You need a good old-fashioned dial-up modem (which we all used to use to connect to the internet before broadband). You clearly have one of these, otherwise you wouldn't be able to receive faxes.
So you should have a cable from your Broadband modem to the phone line, going into the broadband (DSL) filter ADSL port. You should also have a cable running from your dial-up modem socket into the broadband filter phone port (you may also have a phone going into this, so you will need a phone socket doubler to take the phone wire and the dial-up modem wire).
So, to send a Fax, you need to run your Fax program (usually the Windows XP fax module) and set up your system for dialling out. If you need help with this post a new connebt.
Jan 09, 2009 | Epson Stylus C86 InkJet Printer
Wireless-G Linksys Router No Signal with Verizon Modem
The first thing I would recommend is to reset the router to its factory defaults. Then reconfigure it according to your Verizon settings.
There are a number of things you need to set, in order for the router to be able to talk to Verizon correctly. These things such as dns name servers, the ip address you connect to (whether it is static or dynamic), and things of this nature. They should have given you all of this information, and if they did not you will need to contact them first or you will not be successful in connecting.
To be more specific regarding the error message, I need to know the specific model you have as well as the version of the software.
If you need additional help just post another question here and it will notify me that you have.
Jun 19, 2008 | Linksys Wireless-G WRT54G Router
Dell latitude c640
Hi
Both Dell Part numbers 18THT and 5W299 are 8X DVD-ROM Drive Modules. DPN 18THT is compatible with Latitude C series and DPN 5W299 is compatible with Latitude D series. The two drives have different and incompatible connectors.
Your Latitude C640 is a C Series Latitude. You can therefore not use DPN 5W299.
If you need a DVD drive module, get DPN 18THT or an alternative Latitude C series drive.
Mike
Apr 25, 2008 | Dell Latitude C640 Notebook
Need download cd for modem/soundcard
Hi, You can try & proceed to HP website (http://www.hp.com/) and go to the Software & Driver Downloads (left side near the bottom). You have to determine the specif model/version of your HP computer which might look something like "HP Pavilion 4550Z" From initial indications you would be looking for an Internal Modem/Sound Card that was originally set for Windows 98SE. Chances are that it is a Conexant or Rockwell SoftK56 Data,Fax PCI Modem, with Master Riptide PCI Audio Device. Post back should you need additional information. State your PC's model. Good luck and kind regards.
Oct 07, 2007 | Conexant Rockwell Modem
Dell Inspiron Internal 56K Modem P7125 Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
