Question about Spring Step Tek Nek Rockin Rider Lacey Deluxe Plush Spring Horse
Lost instructions to lucky rocking rider Lacey spring hose
1975 honda 754 kick starter froze how do i unfreze ?
before you run to the shop with your hat in your hand and your wallet out as if you were going to catch rainwater to drink-put the bike into a mid or high gear and rock the bike backwards a few times. Sometimes the gear teeth climb up on each other and the spring doesn't have the 'oomph' to separate the kickstart teeth from the crank teeth. If you hear a sound like a screen door spring being played-then you're probably back in business. It may take a few times to dis-engage the kicker if this is what happened. Usually this jamming occurs when the rider jacks down on the kickstarter rapidly. Speaking from experience on a Honda 450 twin-cam. Good luck!
Jul 07, 2012 | Motorcycles
I HAVE LOST THE INSTRUCTION MANUAL & WANT TO USE THE SCALA RIDER WITH MY garmin nuvi sat nav
Please find here a link to google search where the first 2 results are for the scala rider headset
http://www.google.com/search?q=scala rider user manual
Jun 20, 2011 | GPS
Tyre pressures front & rear
Look at the sidewall of both tires. There will be a 'MAX PSI' embossed on the tire. It will probably say Max 45 PSI. At 45psi the bike will ride like a rock. At 15psi it will ride really squirrely. Find a psi at which you feel the bike handles well and rides well. One rider may weigh 125 pounds and the next rider may weigh 300pounds. The best psi for each rider will be different due to weight.
Jul 26, 2010 | 2001 Gilera Coguar
What is the recommended pressure for a 2004 vstar custom?
Look at the sidewall of both tires. There will be a 'MAX PSI' embossed on the tire. It will probably say Max 45 PSI. At 45psi the bike will ride like a rock. At 15psi it will ride really squirrely. Find a psi at which you feel the bike handles well and rides well. One rider may weigh 125 pounds and the next rider may weigh 300pounds. The best psi for each rider will be different due to weight. Generally 35psi works for most riders.
Could you take a moment and rate my answer? Thanks!
Sep 19, 2009 | 2004 Yamaha V Star Custom
My kids have lost the assembly instructions!
Sadly, no: Playmobil is very strict on copyright. See the PlaymoDB FAQ for direction on ordering paper plans from Playmobil:
http://playmodb.org/playmodb_faq.html
For an inventory, see the set page at PlaymoDB:
http://playmodb.org/cgi-bin/showinv.pl?setnum=3269
Apr 03, 2009 | Playmobil Rock Castle 3269
I need instructions for the National Geographic Rock Tumbler.
Complete instruction manual to be found following the following link: http://www.sbdirect.biz/_download_files/NG09.pdf (my son also lost the instructions and I had to search the web to find another copy...
Mar 16, 2009 | Toys
How do i get into the cabinet to remove an obstruction from outsi
hi from uk if the object sounds as you say between outerdrum and wash drum ? may i suggest you unplug machine and disconnect water supply pipes then remove the rear panel this will give access to the main drain hose from bottom of outer drum which also connects to drain pump this hose is rubber and held usually with circular spring clips each end ? remove hose and you may be lucky the offending item/s?? will be resting hopefully near hole? if you use a piece of wire coat hanger you may /will locate item at the bottom of drum with a little patience? and you never know thge mysterious missing sock ? bra wire/ or the thong ? sure you've heard this b4 ? ps with rear panel off you can also rock the drum and listen for item's location ? and with hose off you can check pump for debri/fluff too hope this helps best wishes
Feb 16, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lost instructions re playing /installing Rock Band in PS@
         For how to use rock band. Please try the link below.
 http://guides.ign.com/guides/958392/
Hope this will fulfill your requirment.
 Thakns.
Nov 19, 2008 | Sony PlayStation 2 (PS2) Console
Honeywell Humidifier HUT102m
I've been having problems with this unit since purchase in December 2007.
To fill, unscrew the cap with the spring loaded plunger. It may be tight, but it has two slots which you can turn like a screwhead using something wide enough (eg, a spoon) for leverage.
My problem is that this thing leaks badly. The fit of the cartridge is terribly designed. The one supplied is different from the one depicted in the unhelpful manual, which is silent on where the cartridge should fit. It will fit in one spot, but it will not sit flush with floor of the unit; it rocks and the water holding top rocks with it. The supplied cartridge appears to be an attempted and unsuccessful fix of a problematic design.
Even without the cartridge, this unit still leaks.
A web search shows others complaining about leaking. Hate to say it, but another example of lousy American design... but it sure is pretty!
Haven't been able to raise the manufacturer "Kaz" on the phone.
Jan 13, 2008 | Honeywell HUT-102 1.2 Gallon Humidifier
Spring Step Tek Nek Rockin Rider Lacey Deluxe Plush Spring Horse Logo
23 people viewed this question
Top Spring Step Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Spring Step Toy Expert? Answer questions, earn points and help others
