Question about Oreck steam-it Stick Vacuum
Oreck a100lrh steamer will not heat
My oreck steam 100lrh will not heat any more the green light went out the first week and now the steamer is a year and half old and will not heat at all
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
The power turns on but the steamer will not turn on at all, it doesn't even light up the green button.
if its new take it back to store to be replaced or contack tell them what it is doing the will tell u ok god bless u jesus loves you j316 kjb please read it
Oct 08, 2013 | Oreck steam-it Stick Vacuum
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
I need a manual for the oreck floor steamer
Hi! Since you didn't mention the model type of your floor steamer, i'm giving you the link where you can see the user's guide for all oreck floor steamers. So, access this link (http://www.oreck.com/Owners-Guides) and go to the floor machines category (under electric brooms).
I hope this will work for you! Have a nice day!
Sep 02, 2011 | Oreck steam-it Stick Vacuum
After approximately 5 uses my Eureka 313A steamer will not heat. It has a green light so I know it is getting power. But it will not heat at all. Also, what is the warranty period?
the warranty is one year on this unit. It does sound like there is a problem with the power going to the heater on this unit, or the heater itself. If it is still under warranty, take it to the closest eureka dealer.
Nov 06, 2010 | Eureka 313A Stick Steam Cleaner
Shark steamer wont work. Green button came on and went off. No steam. Have used steamers for long time. What do I need to do?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
hhhk
Aug 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Oreck steam-it Stick Vacuum Logo
47 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
