Question about Samsung Refrigerators
How to fix a leak on a sumsung RS21 assy tank water
The water bottle has a leak that i would like to fix with silicon but realise it is not going to hold. please advice
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Water Leaking from Cold Water Holding Tank
Once you get to the tank , there are 2 hoses . Cut the hoses to remove the tank . Do not push the water dispensor afterwards , or water will run into the fridge . The icemaker water is not connected to the tank , so removel (or non removal ) does not matter . If you had given the model number , I could have given you the part number for the tank (resevoir).
Posted on Aug 23, 2009
  • 183 Answers
SOURCE: How to replace and remove the water tank assy on the Samsung srs584dp due it's leaking from the watertank, possible a lil crack
if you remove the crisper drawers you should be able to see a cover for your water tank. and it may only be a coil of tubing.. wait till you get the part before you start.
Posted on Jan 08, 2012
Why is my bloomfield leaking?
Depending on where it is leaking there are several places. I will illustrate in this drawing. The biggest problem on "non-water line models is the silicone elbows. Check them first. Unplug the brewer and remove the top burners and cover. Then get a pitcher of water and plenty of towels then start slowly pouring in the water and see if is starts filling up the top of the tank lid with water. if it does. remove the pour in tank, then remove the rubber/silicone elbows and if they come out easily, they are bad. Replace them. If you are going to replace them also replace the small 1/4 inch line that goes to the fill basin from the tank. It is about 8" long. Good luck.
Jul 15, 2014 | Bloomfield 8571 Coffee Maker
Where is the water bottle in samsung rs21?
For a schematic of the refrigerator, including the location of each part, refer to the user manual:
Samsung RS21 manual
Dec 23, 2013 | Samsung Refrigerators
TANK LEAKING CAN IT BE REPAIRED AND WITH WHAT
Find the leak. If it's just the drain plug leaking, see if it has a rubber hose washer in it - could be a simple fix. But if the tank itself has a crack or hole in it, go to any home improvement or hardware store and get clear GE silicone (not latex or silicon/latex caulk). Thoroughly clean and dry the plastic around the leak. Apply the silicone. If you can force a little into the crack or hole itself, do so, then run a thick bead of silicone over the leaking area and spread it out gradually so it feathers out to about 1/2" on all sides of the leak. Clean your fingers or tools with paint thinner. Let it dry a full day before you test it out. Good luck!
Jul 29, 2010 | Agri-Fab Agri - Fab 15 Gal. Sprayer
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
Water leaking out of the washer bottle and appearing in the driver footwell- help
replace washer bottle while its out silicone the inner fender where the water is coming thru
Mar 04, 2010 | 2005 Hyundai Santa Fe
RS21DABB- water dispenser will not dispense anymore. Mechanically intact but no flow! Rest of fridge/freezer perfect!
no water can be the early signs of the common issues with samsung rs21 models
what happens is the fridge cooler /defrost system goes faulty and freezers the water instead of chilling it , the best way to check is to take the 2 drawers out the bottom section of the fridge you will then be able to see the water bottle , if there's a lot of ice around the bottle then this would confirm a defrost issue , you can heat the bottle for 10 minutes or so with a hair dryer etc , if the water starts to work after this then you probably will have to call an engineer or fit the rs21 diy fridge repair kit
this video may help
Dec 17, 2009 | Cell Phones
My tank emptied after 2 bbq's.
with the gas bottle turned on make up some washing up liquid in a bowl bursh it on joints to see if you have a leak it will bubble up if you have , the try it with burner on on the gas controls
Apr 12, 2009 | Thermos Quick Set Gas Grill 4000
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
