How do I replace the flame effect bulb on my Valor 846 electric fire
2 Suggested Answers
  • 4 Answers
SOURCE: the flame effect on my
The LED is on a circuit board located inside the fire. The board itself needs to be replaced.
The part would be available from valor spares under your warranty.
The number for valor spares can be found at Valor fires
Posted on Feb 18, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
No visual fire - did the lightbulb burn out?
Yes - Replace bulb per your owner's manual instructions.
Make sure to use the recommended bulb type & wattage to ensure proper flame effect.
Jan 26, 2013 | Dimplex CS4416 Electric Compact Heater
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
The flame effect on my valor 846 electric fire is not coming on, i think it is an led that is not lighting up. how do you change the led and where can i get one. thanks Gerald
Dec 26, 2010 | Stoves Heating & Cooling
I have a wall mounted electric fire with flame option,I have changed the bulb but cannot get the flame effect to work. The falme wheel is turning but no light effect.
have you checked fuse to bulb some electric heaters have a fuse for bulbs and fans so it might be a small inline fuse that you need to change
Nov 22, 2010 | Heating & Cooling
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
Charmglow electric fireplace . no light for flame effect
the fan is working. I do not have the flame effect fixed. I find this web site difficult to get any help from.... seems to go around in a circle. Just tell me if it can be fixed.. I want to know about the bulb (?) or whatever makes the flame effect. Nothing seems to be able to take apart , if not do you have a website I can get to for a new one.....thanks....
Mar 25, 2009 | Fire Sense Georgetown Electric Fireplace
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
