Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Dishwasher is not giving out water
Hi i have just inherited a dishwasher from my father - once we have wired it all up there doesnt seem to be any water getting into the dishwasher why would this be? Please help
    Scholar:
  • 93 Answers
Call a plumber to check your water pipe or you could twist the tap cap back and fort. Runs the dishwasher, if no water still. change FILL VALVE this is an electro-mechanical device that opens a valve to allow water to flow.
May also be called a WATER VALVE or WATER FILL VALVE.
If this does not solve the problem , you need to change the control board.
Does sugestion solve your problem? let me know.
Posted on Jul 24, 2008
SOURCE:
My dishwasher doesnt get the top shelf clean and doesnt seem as though water is even getting to the top. the bottom is marginally clean and the utensil rack on the door doesnt get wet at all. any advise...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher starts bnut doesnt seem to be pumping water in?
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 24, 2010 | Dishwashers
Dish washer doesnt clean soap out of tray but getts water almost seems like the water blades arent spinning
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher is giving E1 which according to the manual is water sorce is off. We recently had turned the water off for bathroom repairs but the water has been turned back on, we have disconnected the pipes...
This is common, there may be a flood protection device that tripped in the line or sediment got into the system when the water was turned back on.
First turn the water off to the dishwasher. Take the hose or pipe off at the connection under the dishwasher, put a pan or towels under that open pipe. Slowly turn the water on and flush that line until clear. If no water comes out then you will need to do this but further back 'upstream'.
Once water comes clear, turn the valve off again reconnect the pipe/hose to the dishwasher and very slowly open the valve. If the water does not enter now you have sediment in the water inlet valve on the dishwasher itself and that valve will need replaced.
Jul 30, 2010 | Maytag Dishwashers
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Smeg dishwasher sa 623 x-1wont work
The water supply may be turned off
Sep 25, 2017 | Dishwashers
Inherited diplomat dishwasher with my house
Today's dishwashers use less water and less electricity so the manufacturers have had to increase wash times to get good results. One hour is about normal for the "eco" cycle since it's always "sensing" the water turbidity (soil in the wash water) and water temperature, and making adjustments as necessary.
Your shortest wash cycle would be "delicate" but it might not give you the best results.
Mar 05, 2009 | Dishwashers
Whirlpool dishwasher
Hi jamesward,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher turns on and you can hear the motor but there doesnt seem to be any water going in
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Dishwashers
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
127 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
