Question about Siemens Lands Phones
Base station is flashing all the time on my Gigaset A400 TRIO.
The other units are fine-no flashing
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
  • 518 Answers
SOURCE: siemens gigaset 4215
Then the base is bad. I have 1 base like that also... nothing can be done other than send it out to be rebuilt.
Sorry,
Geno
Posted on Mar 22, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Posted on Jun 16, 2008
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
richa33
  • 71 Answers
SOURCE: Base station and units all say 'searching'
You may need to register your handset to the base.
Normally ,there is a advanced setting ,register handset. At the same time, press and hold "page" key on your base 4 to 5 second , there is be a registation success tone from handset. You can register all of your handset ,one by one. Some model need to input register code, normally ,it is 1234 , or 0000.
Posted on Jan 21, 2009
How do i fix my landline phone?
hmm im not sure if there's an issue with the base for your wireless phones but it maybe that the phones arent able to determine if the base is active (EG the right base for the phones) some may need to be paired up to the base or the base maybe malfunctioning due to the lightning storm (Phone lines are prone to being struck at times which could send a surge to some types of phone bases and ruin them)
Aug 22, 2017 | Siemens Gigaset Digital Cordless Phone...
I am looking to buy a A495H base Gigaset unit to work with my 3 unit A49H phone set
Most modern Gigaset units work together.
I have a pair of gigaset 300 phones and three newer models, and a BT Diverse 2000 phone, all talking to the same DECT base station (a VOIP N300IP).
Feb 12, 2015 | Siemens Gigaset A495-4 4 handset cordless...
Gigaset instructions
Base unit isn't connected to a live phone line.
Sep 03, 2014 | Lands Phones
We have a A400 phone, how can the flashing red light be deactivated on the message key
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 22, 2014 | Gigaset A400 Dect Cordless Phone - Single
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Sep 04, 2007 | Siemens Gigaset 8825 Cordless Phone
Lands Phones Logo
149 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
