Question about Lite On LH-18A1P DVD RW Dual Layer Burner
I am currently using Windows Vista Ultimate and cannot seem to get my Lite-on DVD RW drive to work. Windows recognizes the drive and tells me that the newest drivers are installed, but nothing! It worked fine with XP. I have tried contacting Lite-on and that was a big waste of time. I was told to contact Microsoft? Any help would be greatly appreciated, thanks!
  • 4 more comments
  • Anonymous Nov 03, 2007
    I have a Liteon SHW-160P6S and have exactly the same issue. The drive worked fine under XP and will read CD and DVDs fine but is not recognized by Vista as a burner. If I remove my new Vista drive a reboot on the old XP SP2 drive, the drive burns fine.
  • yugdlo63 Nov 28, 2007
    I have a lite-on in my new Vista machine and it doesn't recognize any type of disc. Once in a while right after a boot, it will work one time. There are no drivers to change, since the Vista drivers are the only one available. I've tried writing to a black CD and it never finishes (on the rare ocassion it even recognizes there is a disc).
    I've uninstalled and reinstalled. I even reloaded the firmware. No luck.
  • shocko18 Feb 25, 2008
    I have the same problem with 18a1p, Vista recognizes it fine and says it is working properly but when I insert a Cd or dvd it spins the disc for a while then stops and the cd is ejected and the message "insert disc" pops up. I was thinking it might be a BIOS fixable item but it's not, if it were Vista wouldn't show it on My Computer...I had this drive installed on my XP and it used to work perfectly...I couldn't find anything on the Vista help page or the Lite-on one...any help anyone?
  • Anonymous Jan 02, 2009
    Same..
    It worked for a good 6 months on vista then stopped to work.
    I cant do **** without it working..
    Not even reformat.
    Ive come to the decision to put it into a shop..
    Or maybe hook up another drive??
  • Anonymous Jan 31, 2009
    same goes for me what the F! it only reads one time but after ejecting the same cd and inserting it again the device cant read it...it doesnt work on my vista and xp os i have tried to upgrade the firmware but its no use what should i do? can anyone how knows how to resolve this issue? is lite-on knows how to resolve this issue? is this mean that lite-on products are just a bunch of craps? please let us know by the next time we'll purchase a dvd-rw device we will not choose lite-on anymore
  • Anonymous May 02, 2009
    I too have the same problem with LITE-ON DVDRW LH-18A1P. I ended up buying a new one: ASUS DVDRW 22X Multi-S Drive.
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
Posted on Oct 09, 2008
6ya staff
SOURCE:
Why does eject dvd not work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
good luck
Oct 02, 2010 | Lite On LH-18A1P DVD±RW Dual Layer Burner
Lite-on dvdrw LH-18A1P PROBLEM
insert correct cd rom comes only in 2situations
  1. if the software requires to start with the help of cd. try to start program with cd inserted in CD ROM
  2. software is pirated. if it is pirated then in the cd there must be folder named "crack" in it. copy all the files of crack in program files of software
  3. pls rate my solution
thankyou for using fixya
Feb 14, 2009 | Lite On LH-18A1P DVD RW Dual Layer Burner
Lite On LH-20A1H DVD RW burner refuses to recognize DL disks?
I have an LH-20A1S, & I am using Roxio Easy CD
Creator 6; Yes, I know there are newer versions, but they all ****! Anyway, it USED to work just fine in recognizing DL DVD's W/the updates from Roxio's site. & now there is no option there for this size (8.5)w/in the actual Creator prog. Is it the drive? This JUST started happening recently. Any clue if it IS the drive? & if so, any idea what caused this? I've always used Lite-On's & have NEVER had this sort of prob before! & of course it is out of warranty, & a discontinued model to boot! standar DVD drives are real cheap inprice these days, but STILL I do't wanna have to buy an new one if I can 'fix' it. BTW, I have updated the latest firmware for this drive from Lite-On's site too, & it didn't resolve this issue either!
__ERIC
Jan 31, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lite-on dvdrw lh-18a1p does no reconize music cd`s or dvd movies.
If you are trying to copy store bought dvds most have anti copying protection built in which will not allow a dvd burner to recognize them. I hope this helps.
Dec 23, 2008 | Lite On LH-18A1P DVD RW Dual Layer Burner
Lite-on dvd drw lh-18a1p
Media Center Edition 2005 XP - Will not burn with any of my software, NERO, SONIC RECORDNOW OR MICROSOFT.
Oct 09, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
Problem with DVD + R
If your product was made before july 2007 you could try the firmware offered here on the lite-on website. Download the firmware zip file and extract then run the exe file inside.
Jan 15, 2008 | Lite On LH-18A1P DVD RW Dual Layer Burner
Copywrited DVD Movies require that an MPEG software DVD Decoder be installed on your system. Windows doesn't include any because of their Anti-Trust violations and court issues.
(not to be confused with other media players, and DVD players that are included with DVD Movies, such as HOTLLAMA, and Interactive - you still need a DECODER. This is a throwback to the early days of PC DVD ROM's that required a HARDWARE MPEG DVD DECODER be installed, usually in a PCI slot, and connected to your video card through the VESA expansion connector. Nowadays, the hardware is built into the DVD unit, but it still requires a software decoder to operate).
Every DVD ROM or Burner comes with one...usually "Cyberlink PowerDVD", and now Nero's included one in their bundled OEM package.
Any version of any one of these will unlock the "DVD Movie" features for all media player installed on your PC.
[oops, almost forgot, you need Nero 7 or better for Vista. Any Cyberlink should work for you].
If you don't have one, try borrowing one from anyone who's got one. You can also go the P2P route, and download one, if you're so inclined.
Good luck, and I hope that fixes your problem!
Jan 05, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
My XP computer not recognizing drive anymore
Same thing just happened to me, trying to find a solution as I write, if I find anything I will post back!
Dec 08, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Lite On LH-18A1P DVD RW Dual Layer Burner Logo
1,711 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
