Question about Lasko Ceramic Heater
Error message 88 on lasko heater
I keep getting a 88 error message on my lasko heater after it has ran for awhile.
3 Suggested Answers
SOURCE: Lasko 5610 red caution light, no power
In the bottom of th e 5610 there are 2 automatic reset breakers. In betwene the two there is wire connecting them together. In the middle of this wire is a thermal resister and thats what repaired mine. Replace it and your heater will heat again.
Posted on Mar 06, 2008
  • 12 Answers
SOURCE: how do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
If its a central heating unit you should make sure the batteries in the thermostat are good and the fan switch is on auto. then you can open the cover to the heater and tap on the relay. that will usually shut it off if its just sticking. It could be a black box by itself or a box on the circuit board depending on the model
Posted on Nov 29, 2012
Lasko 5132 heater will not oscillate. Any suggestions?
did you try unplugging it for a little while and letting it reset?( it says 5 mins)
I had one and at 1st doing that worked...and after awhile I found out it was getting too hot (mine even warped).
Dec 03, 2014 | Heating & Cooling
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
How do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
Nov 29, 2012 | Lasko Heating & Cooling
I have a heater that keeps turning itself off even though I have the thermostat set at 70
probbaly a limit switch,not easy fix.got to open it up, short switch and run awhile if its ok then replace limit or risk fire.if it still quits then its thermostat.sometimes there is a tiny little screw behind the knob you can adjust
Dec 29, 2010 | Lasko Heating & Cooling
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
My lasko 5160 is flashing 88 with some other lights on,what do i do
At least for the Model 5165, the "88" means there is a circuit error -- probably applies to other models as well. First, call Lasko Customer Service 1-800-233-0268 (M-F, 8AM-5PM, EST). Have your receipt ready. Lasko will ask for a engraved number at the bottom of the heater, may have to look a few times to see it, normally about the serial number. Hope this helps!
Nov 16, 2010 | Lasko Heating & Cooling
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Model 5800
In page three in the manual it shows you how to set your temperature settings.eb6548e.jpg
Oct 30, 2008 | Lasko Ceramic Heater
Lasko  Ceramic Heater Logo
54 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
