Question about Garmin Nuvi 660 GPS Receiver
Garmin nuvi 2505 memory full - Garmin Nuvi 660 GPS Receiver
marcelbakker
  • 174 Answers
SOURCE: garmin memory stick
You erase it when it is connected to the computer, why do you want to do that?
Posted on Jun 10, 2008
SOURCE: garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Posted on May 22, 2009
  • 3 Answers
SOURCE: Memory Full - Garmin nuvi 200
Turn off the device, push and hold in right-down corner on the display, and turn on the device. Hold your finger on the display, until you see "Do you really want to erase all user data?" message. Then click "Yes"...
Hint:
All private data will be erased. The user POI's too. You can backup the file G:\Garmin\gpx\current.gpx before erasing procedure.
Posted on Jul 21, 2009
emissionwiz
  • 76846 Answers
SOURCE: garmin nuvi 205
TIME FOR A TRIP TO GARMIN
Posted on Feb 26, 2010
  • 343 Answers
SOURCE: garmin nuvi 610 memory full
You can attach the unit to your computer and then delete some information like extra voices, languages, help files, pictures, etc. You can also delete from the gps menu old locations and favorites.
Make sure you make a copy of everything first before you delete anything.
Thanks for using FixYa
Posted on Aug 24, 2011
How do i set home in my nuvi 2505 when the wrong address was added at first
To change the home address on the Nuvi, select Where To? on the left side of the main screen. Then choose Saved > Home and then press i > Edit . After you make the needed changes, press Done. (To edit some Saved items, you have to press Menu (the icon with the horizontal lines) after pressing the i button to see the Edit option.)
The manuals for the Nuvi 2595 LMT and the 2505 are available here: http://support.garmin.com/support/manuals/manuals.htm?partNo=010-01002-01&language=en&country=US .
I hope this helps.
Sep 29, 2012 | Garmin nuvi GPS
Garmin nuvi 1340 freezes on start up
If your nuvi series device is freezing on the map screen but still providing voice prompts there are two steps you can try to resolve the issue including updating the software using WebUpdater* and performing a master reset.
To download WebUpdater and update the software:
  1. Go to http://www8.garmin.com/products/webupdater/howtoinstall.jsp
  2. Follow the on screen instructions.
To perform a master reset on your nuvi series device: CLICK HERE
Warning: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 18, 2010 | Garmin nuvi 1300 Car GPS Receiver
Screen says memory full
first off try to back it up to a computer then get a larger SD card and restore to that.
Aug 09, 2009 | Garmin nuvi 350 GPS Receiver
Hint:
Mar 23, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 GPS will not find sattelite
I GARMIN KEEPS SAY MEMORY IS FULL HOW DO DELETE IT
Feb 12, 2008 | Garmin nuvi 350 GPS Receiver
Memory full is being displayed when i try to go to a new destination and when i try to delete a favourite the unit turns off.
Garmin nuvi 610 T
memory full was being displayed on screen whilst on destination ,sometimes followed by route waypoint memory full .
I found by turning unit off , then holding finger on top left of screen ,and at the same time turning back on again the unit would go into maintenance mode.
Follow prompts on screen to reset waypoint memory.
Mine works as good as gold now,hope this helps!
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Says memory full and will not work
Hi dogman33, This is a common problem with the nuvi 660s with older firmware. Garmin's solution is to perform a "hard reset" and to upgrade the device firmware. Upgrading firmware is an easy procedure, just visit Garmin's website (www.garmin.com) and download the software called WebUpdater. Run that and follow its directions. Here is how you can perform a hard reset to clear all your waypoint memory: MAINTENANCE MODE: Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer. Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?" Step 3. Select the yes button. Step 4. Enter your PIN if enabled. Step 5. Main Maintenance Mode screen should have 4 selections: System information View Diagnostics Clear User data Clear Waypoints Step 6. Choose "Clear Waypoints". After some time the unit should reboot. Hope this is helpful! spydee
Jul 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
