Question about Brother HL-6050DN Laser Printer
I need to reset pf kit 1 life on a brother 6050dn....holding down the go and + buttons does not give me access to the appropriate menu as the brother web library would suggest it should.
SOURCE: Brother HL-5270DN PF Kit Problem
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
  • 5 Answers
SOURCE: toner end of life
press Go and Set at exact the same time
press < one time
press Set
choose "Nothing"
press Set again
Posted on Jul 13, 2009
SOURCE: HOW DO I RESET THE DRUM KIT COUNTER ON A BROTHER
open the door and press clear/back and then press 1
Posted on Dec 15, 2009
SOURCE: Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Posted on Feb 08, 2010
angelo_mlc
  • 1035 Answers
SOURCE: how to reset brother mfc
Hi. Here's the procedure.
1) Turn off printer
Posted on Oct 23, 2010
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
My PF KITMP life is at 90% can I reset this and get more life out of it or will I have to replace at 100%
PF KitMP is the Manual Feed Paper Kit. Normally these count down not up. If it is counting down there is no need to replace it any time soon.
The life on the kits is based on a certain number of pages being fed through it. The rollers wear with every page sent through. These rollers when the kit expires means they are probably worn smooth and not able to pick up the paper anymore. There are ways around the wearing of these rollers so you may not need to replace them as soon as it expires.
On the machine there will be a maintenance option in the menu which includes parts life and resetting of said parts. I would assume that the parts are going to be available for quite some time since most people dispose of the machine before the PFKits run out. So check with your Brother Supplier for parts availability. The kits are not too expensive normally.
Sep 08, 2014 | Brother HL Office Equipment & Supplies
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
REPLACE PF KIT1
THIS IS HOW YOU WILL RESOLVE YOUR ISSUE OF REPLACE PF KIT1 ON UR Brother MFC-8460N All-In-One Printer
1) Turn off printer
THIS WILL DEFINATELY RESOLVE THE ISSUE
REPLACE PF KIT1 : THIS IS IN REGARDS TO THE MAINTENACE DISPLAY THAT YOU HAVE ON YOUR PRINTER
TAKE CARE AND HAVE A NICE DAY..
Jun 22, 2010 | Brother MFC-8460N All-In-One Printer
1) Turn off printer
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother HL-6050DN Laser Printer Logo
48 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
