Question about Hitachi C12RSH 12" Sliding Compound Miter Saw withLaser
HOW TO REPLACE SPRING ON HITACHI MITER SAW - Hitachi C12RSH 12" Sliding Compound Miter Saw withLaser
2 Suggested Answers
  • 1388 Answers
SOURCE: Electric Blade Brake is not
Brake is controlled by the switch. There are two switches that can be used on your saw. One switch has only on/off, the other switch is on/on. On motor when pressed and on brake when released. The switch with brake does not last very long because the braking action is really just shorting motor circuit (short circuit). All motors can produce electricity. The brake action occurs by shorting motor thru switch. Electricity that motor is producing while turning forces armature to stop. Other brands use a resister in breaking system to absorbe current help switch last longer. Parts are available at www.toolpartsdirect.com Good luck
Posted on Sep 07, 2010
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
How do i replace switch on Hitachi miter saw
Oh come on.
You know the answer.
You start taking out screws until you can see the switch and then you replace it with a new one from the parts supply store.
Then you put all the screws back in.
Oct 16, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
Cant pull out locking pin on miter saw
There is a heavy spring which is trying to hold up the saw that is working against you. Press down on the handle of the saw so that it moves down a little, now you should be able to pull out the pin.
Good luck.
Jun 13, 2012 | Hitachi C10FCE2 10" Compound Miter Saw
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Jul 15, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Hitachi C12RSH 12" Sliding Compound Miter Saw withLaser Logo
137 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
