Question about Sedu Revolution Professional Nano Tourmaline Ionic Styling Iron
Need to know what size thermal fuse for sedu Revolution Professional Nano Tourmaline Ionic Styling Iron
SEDU flat iron won't turn on when i plug it in...
flat iron has large metal foil so change the procdure
Jan 24, 2014 | Sedu Pro Ionic Ceramic Tourmaline Flat...
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
Change the thermal fuse inside iron that's why not getting hot. thermal fuse blown up due to overheat inside
An iron should be calibrated to 410 degrees on wool setting to get the other settings to work correctly.
Dec 26, 2012 | Irons
I GET NO HEAT IT JUST STOPPED
U got a busted thermal fuse or the thermostat switch is not functioning.
If u have a knowhow in replacing and adjusting the thermal switch, u could fix it by urself!
Better check also the power cord, mostly flat irons main prob, if there are no lights on ur iron, it means internal probs!
Better take that iron in ur friendly hungry technician to fix that!
Dec 02, 2010 | Rowenta Professional DE880 Iron
I have described my problem repeatedly. Again - My Oreck Cord-Free Steam Iron JP8100C series stopped heating
Ok whenever an iron stops heating it is either the Thermal Fuse,or the Element or the actual temperature control. One would have to use a meter to check the Voltage at the element of the iron. & Test the Thermal Fuse.
Also though with Cordless irons it may simply be that your batteries aren't working as they should. They can quickly be ruined if not charged correctly.
I do NOT think, that this is a job for a home repair due to the added complexity that the batteries add.
You need to take it to a professional repair center and ask for a "Quote" before allowing any repairs to proceed. As the cost of repair may exceed the cost of a new one.
Aug 08, 2010 | Oreck Cordless Speed JP8100CA Iron
I have kenmore 81669 iron it is not getting hot
This usually happens for one of a few reasons, Check, Thermal Fuse, Check Element, Check, on/off switch. Check power cable, for continuity.Check Thermostat, Thats all there is inside an iron, Power comes in the Phase, the Black, or Brown wire, then, through the on/off switch, through a Thermal fuse, through the thermostats contacts, to the element, and the other side of the element goes to the Neutral return. usually White or Blue.of course the Earth is Green or Green/Yellow, stripe.and is connected to the metal case..
Apr 23, 2010 | Kenmore Professional SR365S Iron with Auto...
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Red indicator doesn't turned on
where is the thermal fuse for this iron? mine has the same problem, I don't know what to look for.
Jan 04, 2008 | Panasonic NI-H10NS Iron
Sedu Revolution Professional Nano Tourmaline Ionic Styling Iron Logo
57 people viewed this question
Top Sedu Irons Experts
Are you a Sedu Iron Expert? Answer questions, earn points and help others
