Question about Garmin Zumo 665 Motorcycle GPS Navigator Receiver
Garmin 665lm will npt power on
Will not power on. says insert battery
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
Dell inspiron 1525 battery not charging
Try to isolate the battery by plugging the power adapter to it. Then remove the power adapter & press/hold the power button for 5 seconds. Insert the battery, turn on the pc & insert the power adapter , check if the battery is charging. If it is still the same, contact their Dell Inspiron tech support 1-800-601-3355 for battery replacement possibly...
May 28, 2010 | Dell Inspiron 1525 Laptop Jet Black
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Compaq HP nx9600 notebook will not power on, even with known good battery or by direct power. It was working fine before turning off. No lights, no signs of booting or power.
First, remove battery and insert power cable then try switching it on. if it powers, then insert battery back when its powered. if it doesn't power, check your power adapter first and make sure it didn't get blown. check whether voltage is reaching. Regards
Feb 10, 2010 | HP Compaq nx9600 Notebook
When tape inserted re insert tape and C 31:23 APPEARS
The camcorder has detected an issue that may require a power reset. To perform Power reset,
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 04, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Computer will not charge or power up is their some type of reset button? The unit Model NBQ115-TS05/TS09
tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
May 29, 2009 | Computers & Internet
Will not power up, no lights or sound
remove the ram
remove the ac again
insert the ram
insert battery
insert ac
May 29, 2009 | Intel Everex LM7WE Notebook
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Garmin Zumo 665 Motorcycle GPS Navigator Receiver Logo
20 people viewed this question
Top Garmin Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Garmin Audio Player and Recorder Expert? Answer questions, earn points and help others
