Question about Samsung T240HD 24 LCD HDTV
How to reduce brightness in Samsung 'Syncmaster SA10'
It is very bright I want to reduce the brightness. How to reduce it. There is no button in that? How to reduce in my computor? This is my question.
SOURCE: Samsung SyncMaster 193V magicbright
hold the menu button down until the menu disapears again
Posted on Sep 07, 2008
SOURCE: problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Posted on Feb 15, 2009
chanddra2009
  • 615 Answers
SOURCE: Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Posted on Sep 18, 2009
JayAbed
  • 14 Answers
SOURCE: samsung LCD tv, there is excessive brightness in
System conroller PCB would do that
Posted on Jan 04, 2010
  • 1684 Answers
SOURCE: Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 28, 2010
Testimonial: "I know this has been quite some time ago, lol. I did since replace the capacitors and still had an issue. There was another component that went bad (can't remember what) which was too expensive to replace given the price reductions on newer bigger monitors. Thanks for your help!"
Samsung
I would hit the menu button on the monitor,,then look for brightness settings.
Sep 01, 2014 | Samsung SyncMaster 220WM Monitor
How to adjust brightness for samsung syncmaster SA10 monitor ?
Download Magictune from Samsung, it will allow you to adjust the brightness. It can be found here:
http://www.samsung.com/us/consumer/learningresources/monitor/magetune/pop_download.html
Jan 30, 2014 | Gateway FPD2275W LCD Monitor
SyncMaster SA10, my screen turned green, i've tried everything but it's still the same. Help ?
The Blue and Red drives are missing and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung SyncMaster 940MW 19 in. LCD...
Brightness bar stays in the center of my screen Samsung SyncMaster 731N
I'm Adam and i'm a computer-technicien!
I should do these 2 things do hide this brightness bar:
-You can click the MENU button again!
-You can simply disconnect the power-cable from the monitor and
let it unplugged for like...10-15 seconds!
-You can remove the button with a screw-driver and take the
little plastic on the second button.
If this all doesn't work...
I can recommend you to send a email to SAMSUNG with this info:
-Name:
-Date when you bought this product:
-When did this start:
-And your CPU information:
If this all doesn't help...
You ned to install a driver called 'Syncmaster 720n/730n driver'!
Thank you,
May 25, 2011 | Samsung SyncMaster 720N/731N
How to reduce the brightness of the screen?
To adjust the brightness follow this iamge:
Sep 29, 2010 | Samsung Syncmaster 2033SW Monitor
Have a Nice Day
Sep 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
SyncMaster 191t Screen is to dark. Brightness is set to 100%.
make sure you have the latest video driver.
Some video drivers you can configure/enhance your desktop settings.. ie. brightness, gamma, contrast..
If you're using windows, right click on your desktop, click Properties, choose the tab Settings, then click on the Advanced button. Choose your video card tab, and continue accordingly.
Jul 17, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor settings
You can increase brightness by eht .Move button of screen that is placed on eht
Hope this solution works
May 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung T240HD 24 LCD HDTV Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
