Question about Ryobi Snap In Primer Bulb Pump 683974 Blower Trimmer
How to replace the primer bulb - Ryobi Snap In Primer Bulb Pump 683974 Blower Trimmer
2 Suggested Answers
  • 6 Answers
SOURCE: primer bulb ruptured Hard to replace &
they are not hard to replace. Any small engine repair shop carries the kit.
Posted on Aug 16, 2009
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
Replace a primer bulb on a Homelite Mighty Lite 26cc trimmer
There should be two to four screws right around the primer bulb cover, which is located around the primer bulb. Remove those and switch the primer bulb out.
Aug 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
The primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Jul 18, 2009 | Garden
Need diagram/instructions on how to replace primer bulb on briggs and stratton push lawn mower My primer bulb has busted so I'm trying to replace. Don't know how to get the old one out and replace.
Unless they have changed, all you have to do is unscrew the old primer bulb and screw the new one on in it's place. The primer is composed of the rubber bulb with a metal or plastic ring with threads on it where it connects in the fuel system.
Jul 17, 2009 | Garden
Primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Jul 06, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi Snap In Primer Bulb Pump 683974  Blower Trimmer Logo
51 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
