Question about FinePrint Software pdfFactory Pro
Fine print serial 8.0 - FinePrint Software pdfFactory Pro
I'm not getting communication from the RS-232. Is there a setup I need to do or something?
To setup connection first find serial settings by:
Hold feed button whilst switching on label, will then print configuration and do a calibrate.
from the configuration print find settings for serial port format is something like " Serial port : 9600, N, 8, 1 "
set your PC to the same settings. This should work just fine.
Jun 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Tip
USB to serial Cable Problem
Windows will recognize the printer but fails to print. I have installed the driver but nothing. It will print fine using the regular serial cable.
on Oct 08, 2008 | Fargo Persona C16 Thermal Printer
Which port should I use for my printer: com 4 serial port com 6 serial port com 8 serial port usb virtual printer port
depends how your printer connect
if you realy are connecting an old serial printer com1 or com2 should be fine as long as you do not have a mouse or a modem on them ...
if USB any port is fine
if parralel printer you are only likely to have one...
Mar 18, 2011 | Computers & Internet
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Aug 11, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I850 Color Bubble Jet Printer/Serial No. FBHP20999 When I print. I have vertical lines 1/8'' across the complete page. (Cyan). HELP!!
In your print driver there is the option (nder Maintenance) to clean the heads. Run this and then run a test print. It should remove the lines. If it doesn't run again. If you haven't used the printer in a while it may take several cleanings to correct. If after 4 or 5 cleans, the problem still exists, buy a new cartridge; your current one is dead (even though the other colours may be fine).
Jul 07, 2009 | Office Equipment & Supplies
Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Apr 04, 2009 | Zebra S4M Thermal Label Printer
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Computers & Internet Logo
27 people viewed this question
Top FinePrint Software Computers & Internet Experts
David Payne
David Payne
Are you a FinePrint Software Computer and Internet Expert? Answer questions, earn points and help others
