Question about Fitbit Ultra Wireless Activity Tracker - Blue - Blue
My fitbit is splitting
The seam has started to come apart on my fitbit. Does anyone repair them
Just received my fitbit blaze and I don't know how to set it up
Fitbit Setup
Note that only setting the time zone can be done manually. The specific time is derived by syncing with the primary device, not the fitbit.
Sep 25, 2017 | Exercise & Fitness
The band on my wife's Fitbit has split. Is it possible to order a new one?
My friend emailed Fitbit when the wriststrap on hers started to break. They've just sent her a new one & don't want the old one back.
Jan 29, 2017 | Exercise & Fitness
Hot tub cover is splitting at middle seamline
as long as the cover fabric is not damaged or torn then the seam
should be able to be resewn
Jan 07, 2013 | Sewing Machines
The seam on walking belt is coming apart.
will be a great Idea to contact www.weslo.com go weslo customer service or send email to service@iconfitness.com
Since they are the manufacturer , they will have specific Tip for the seam,
God bless you
Jan 04, 2013 | Weslo Cadence 845 Treadmill Walking Belt...
The seam is coming apart around the foot opening and i need new soles
These things happen after about 5 years of use. Since Dansko moved production out of Europe, there have been quality issues showing up more frequently. If you need new soles, it could be that they split. If they have split, there is nothing that can be done that will permanently fix them. If the tread has worn off, that can be replacd at a shoe repair shop.
Apr 03, 2011 | Dansko Narrow Pro Shoes for Women
Need to repair a small seam crack/separation in Uvex
Is it just the paint/finish or the body/neck itself? If it's the finish splitting(happens on many old instruments) then its nothing to worry about. Keep the instrument in a dry place that is around 70 degrees. If the splitting is in the neck joint itself then get some glue and repair it.
http://www.stewmac.com/shop/Glues,_adhesives.html
Jul 29, 2009 | Music
Electric Dryer Thumps
that gap in the drum is most likly hitting a roller in the back of dryer so my best guess is replace drum if you feel it's not that change the felt around door thank you for useing fixya rate me
Apr 01, 2009 | Dryers
Moisture in headlight assembly, 2004 toyota seinna van. How do I take out to reseal or replace? It is the assembly on the passenger side.
Once the factory seal is leaking moisture, it can be hard to dry and reseal. You can try a hir dryer, and then look for a seam to lay silicone on, but the recommended fix is to replace the whole headlight assembly. The lens is not removable like on older lamps. The pieces are molded, and then epoxied together. Hard to split apart and get back together without damaging. Try a salvage yard.
Mar 20, 2009 | 2004 Toyota Sienna
Fitbit Ultra Wireless Activity Tracker - Blue - Blue Logo
27 people viewed this question
Top Fitbit Exercise & Fitness Experts
Ravi
ray gallant
Are you a Fitbit Exercise and Fitnes Expert? Answer questions, earn points and help others
