Canon CLC 1140 Copier Logo
Posted on Oct 09, 2007
Canon 1140 service
Error messages E005 and 0100
Bleddyn Jones
Level 1:
  • Contributor 62 Answers
  • Posted on Oct 11, 2007
Bleddyn  Jones
Contributor
Level 1:
Answers
62
Questions
0
Helped
28703
Points
85
Error E005 means the cleaning web has run out. Needs replacing and ressetting.
1 Related Answer
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Oct 16, 2007
SOURCE: canon 1140 E005 and 0100 error
2helpful
Canon 1140 E000 0105
The error code is letting you know that there is a problem in the upper heater unit in the copier. It could be a bad thermistor, a bad heater, a bad thermal switch, or a combination of any of them.
I would recommend calling it in for service as all of these parts are not user servicable.
2answers
Canon iR-2016 System erro E007
The fusing unit needs to be replaced or repaired. Contact your dealer or service person
System error E.007
Hi, are you sure that you have clc 1140 Copier? Because E007 isnt clc 1140 error code. These error code is related to machines with teflon folie, in newer date b&w copiers.
These error means that copier cant see fixing folies mark, and only that you can do is to replace fixing film ( folie ).
1helpful
ERROR E020 03FF
toner clogging between sub hopper and developing assembly
2answers
Error code
theres an error with either Heater lamp, Thermistor, DC controller
Canon colour copier 1140 error code 20 / 400
black toner consentratin asignel is faulty
1helpful
Canon IR2022i Can't On
you have a language file bootrom error code, you need to reinstall the machines firmware
Re: Canon 1140 E072 0002
change your transfer cleaning assy.
2answers
Canon 1140 E005 and 0100 error
off the top of my head a 0100 error code for a canon usualy relates to network cards. try removing the card and powering up without it in, should help determine if thats the problem. Hope this helps Cops [email protected]
old marine
old marine
ZJ Limited
ZJ Limited
