Question about Linksys Wireless-G WRT54G Router
When i install this update via recovery mode my gica atv box will just show the orange light and nothing comes on the screen. How do i get it to work?
Samsung galaxy s7 stuck in recovery mode bootloot after 7.0 update
Try updating again via your computer. The Samsung support page says Android versions past 6.01 (build G935TUVU4APK1) are not supported. The procedure for letting your computer control the update is provided in the link.
http://www.samsung.com/us/support/answer/ANS00047922
Jul 03, 2017 | Samsung Cell Phones
I tried to flash my nokia 5310-c using noking software update via nokina pc suite and successfully installed the latest version for the mobile phone. But my phone doesn't start now. It momentarily shows a...
Actually what you did was a Firmware update, not Flashing. Flashing is possible only with specific Hardware and software like Jaf box, Ufs Box, etc.. If you flashing using Jaf or Ufs, you don't need to put the battery, the cable that comes with the Jaf or Ufs has batter connector itself which when connected to the phone will power one in different mode (Not nokia mode as you update your firmware using Nokia Pc suite). Once you've updated the firmware, there's no way to revert it back to the previous state.
Now your problem might be fatal and the only solution is to completely flash it using Jaf or Ufs. In this situation, you better visit a mobile repairing shop or a Service center and get it repaired. The software and hardware cost more than the price of your Handset, so doing yourself is not recommended.
Good luck.
Thanks for using FixYa.
Jul 29, 2010 | Nokia 5310 Cellular Phone
My sansa e260 says load main screen fail switch to recovery mode...what do i do?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic go to /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa.
http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related
here is a link to a kid showing you how to go to recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Usb mode in settings MSC is best, Updater recognizes it in this mode
Jun 26, 2010 | SanDisk Sansa e260 MP3 Player
Vista home premium edition keeps rebooting
its nothing u have downloaded the updates for ur system while ur restarting the updates will install so wait some time nothing will happen for data
Feb 25, 2009 | Sony VAIO VGN-NR120E/S Notebook
Sansa e280 Main Image Wont Load Problem, Plus firmware updater doesn't work
Do not worry! I had the same problem as you before and got it fixed perfectly! Go to this thread and read the instructions carefully.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Note that doing this will delete all files in your player, so I recommend you to save your files somewhere before doing this.
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
No sound, just clicking
try recovery mode. to do this just connect it to your computer and push the hold button so the orange is showing. next push and hold the record button and the power button. it should go into recovery mode.
Feb 10, 2008 | SanDisk Sansa e260 MP3 Player
I'm freeze
The firmware of the player is corrupted.Have you tried to update the firmware of the player? If not please follow this steps to resolve this problem. Enable the hold switch for it to show the orange color then press and hold the record and menu button until it shows welcome to recovery mode. Download the sansa firmware updater at the sandisk site and install and run it at in your computer. Then after that it will then be asking you to connect a device plug the player to the computer and perform the update. If the update is successfull you will be prompted to choose a language. hope this helps. :D
Jul 12, 2007 | SanDisk Sansa e260 MP3 Player
Load main image failed?
Hope this would help. Have you updated the firmware of your player? Try updating the firmware of your player. When the player is turn off slide the hold switch for it to show orange/red color. Then press the Record and the menu button until is shows on the screen welcome to recovery mode. Then go to sandisk website and download the firmware update and install it to your computer. When it ask you to connect a device connect the player and update the firmware of the player. If the update is successful then it would ask you to choose a language. Hope this helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
Not working
If your player is frozen. Press and hold the menu button until it turns off and try to update the firmware of the player. And also it may be that the songs on your player is causing the problem try to format the player. How to update the firmware of the player please follow this steps. 1.Slide the hold switch for it to show the orange/red color. 2.Press and hold the record button and the menu button until it shows on the player screen Welcome to recovery mode. 3.Download and install the firmware update. 4.When the firmware update has been installed hooked the player to the computer and perform the update. Hope this helps. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
Linksys Wireless-G WRT54G Router Logo
37 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
