Question about Paradyne (6218-A1-200) Wireless Router (6218A1200)
Paradyne (6218-A1-200) Wireless Router - Paradyne (6218-A1-200) Wireless Router (6218A1200)
5 Suggested Answers
OneMixDJ
  • 21 Answers
SOURCE: Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Posted on Apr 21, 2008
mahal1517
  • 62 Answers
SOURCE: Paradyne 6218 12 200. With dynamic IP address,
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Posted on Jul 23, 2009
  • 377 Answers
SOURCE: Will a Paradyne 6218 be compatible with Windows
read user manual you will get the information about the topic
thanks
Posted on Nov 10, 2010
  • 11800 Answers
SOURCE: The combined Paradyne router and
You buy a new one, you install it in the place of the other and you configure it following the manual - you will need the connection data from your ISP (username and password - they are in the contract).
If you no longer have it you can download it from here
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Posted on Feb 16, 2011
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Mar 29, 2013 | Paradyne (6218-A1-200) Wireless Router...
Will a Paradyne 6218 be compatible with Windows 2000
thanks
Nov 10, 2010 | Paradyne (6218-A1-200) Wireless Router...
My paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Apr 25, 2010 | Paradyne (6218-A1-200) Wireless Router...
I cant enable wireless
must be your router should work on mixed mode. please check your router's setting area for mixed mode setting.
Apr 10, 2010 | Paradyne (6218-A1-200) Wireless Router...
I want to change mtu value for paradyne
You can edit it through GUI or command line. Be careful as to what you set it to as MTU settings can really affect your traffic flow. Read the manual for help
Apr 08, 2010 | Paradyne (6218-A1-200) Wireless Router...
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
Paradyne 6218-I2 ip filter
If you are using multiple computers, and DHCP, then your IP's are probably changing, which is causing your issue. You need to manually assign an IP to a computer for the IP filter to be effective in the Paradyne.
Dec 28, 2007 | Zhone (6218-I2-200) Router
Paradyne 6218 how to reset
The user name : password is normally admin : admin
To reset the router try holding the reset button on the back of the box for about 10 sec. (make sure the power is on while doing this)
Oct 15, 2007 | Paradyne (6218-A1-200) Wireless Router...
Paradyne problem 6218
If the address you mention is correct, try reseting the router first, (normally a little hole at back), then typing in again, although most routers have a 192.168.x.x reference and not 198.168.x.x as you mention.
Oct 15, 2006 | Paradyne (6218-A1-200) Wireless Router...
Paradyne (6218-A1-200) Wireless Router (6218A1200) Logo
42 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
