Question about Baby Gear
Cut thala pajama - Baby Gear
How do I add knit band to pajama pant on McCalls pattern 7975. I have lost the directions.
Usually the cuff ribbing is cut double the required length plus doubled seam allowances (ie 3" x 2 = 6; add two 5/8" for seams = 1.25"'; equals 7.25" long). It is doubled so when it is folded in half and stitched to the leg, there will be no seams showing outside). The width of the ribbing is probably an inch or so shorter than the leg bottom--it should be large enough for the foot to fit through but tight enough that it hugs (not squeezes) the leg.
Sew the cuff together lengthwise to make a circle. Fold it in half with the stitched seam inside. Then fold the circle widthwise with the seamline at one end. Mark the halfway point opposite the seamline. Then fold in half again with the seamline and the first pin matching together. Mark the other two ends. You've divided it into equal fourths. Repeat the same procedure marking the pajama leg in fourths. Then match the seamline of the ribbing to the seamline of the leg (right sides together). Match the other three marks on the cuff to the three marks on the pajama leg bottom. You'll have the stretch the ribbing because it should be a bit smaller in circumference than the leg bottom. Stretch the ribbing to match the leg bottom and stitch the ribbing and leg bottoms together. Turn right side out.
How to Attach Knit Cuffs to Sleeve Shirt Sleeves
sewing with knit fabric how to sew sleeve cuff with knit fabric
Jan 02, 2016 | Sewing Machines
I'm looking for a pijama with a zebra print
http://www.jcpenney.com/jsp/search/results.jsp?fromSearch=true&Ntt=pajamas&ruleZoneName=XGNSZone&cm_mmc=google%20non-brand-_-g_apparel_womens_sleepwear-_-g_zebra_pajamas-_-zebra+pajamas&gclid=CjwKEAiAxsymBRCegqiLzI7Q1S8SJADOgQrzyakr6vgYMAx0fWGHe0bTQnaCGWNAFaTyYBeBXZQ0VRoC_Mvw_wcB&utm_source=google&utm_medium=cpc&utm_campaign=paid%20search&cvosrc=ppc.google.zebra%20pajamas&matchtype=e&cskid=492548017
Jan 10, 2013 | Clothing
I have been given a Husqvarna Viking 545 Lily Quilting sewing machine and it doesn't have a manual could you tell me where I can get a copy? Or is there a website you could direct me to. Thank you, ...
www.husqvarnaviking.com/.../Husqvarna_Viking_Models_compatible_with_the_Fabric_Mover(1).pdf
Please find above the link for your manual. Below is a helpful link too...
www.husqvarnaviking.com/us/media/HVMech2.pdf
Aug 23, 2010 | Vacuums
My washer damages clothes
You should inspect the inside of the drum for damage or something stuck in the drum perforations. I have had exactly this problem and it was caused by the wire from one of my wife's bras coming out in the wash and getting stuck in the drum perforations.
Mar 01, 2010 | GE WSXH208A Front Load Washer
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
