posted by raemartin on Oct 09, 2007
Hi
When ever I start the machine A10 appears on the display, any ideas?
Would be very grateful of any advise
Kind Regards
Rae
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 18, 2007
a10 code , trips circuit off
Best Solution
posted on Oct 09, 2007
Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device.
FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position,
Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer.
Make sure to notice any other codes that may appear. Or any peculiar noises.
Most default codes appear if water pressure is too low.
Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr.
Make sure to check that water strainer is not cloged or restricted.
Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU.
Good Luck ... Be Safe
Joe Rex
Joe Rex
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hotpoint 24 in. FDW60 Free-standing
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Hotpoint 24 in. FDW60 Free-standing...
re white residue
re white residue
thanks for advice, residue was... Answer This...
DISHWASHER WONT STOP
hello my dishwash wont stop at... Answer This...
hotpoint dishwasher fdw60
Hi my dishwasher is just over 3... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
Find Parts
