F8 ERROR CODE IN ONIDA WASHIING MACHINE HYDRO FUZZY 70
ERROR CODE WHILE STARTING ONIDA WASHING MACHIINE
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 1937 Answers
SOURCE: kenmore 70 series washing machine won't drain or
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on Nov 05, 2009
SOURCE: ge hydro heater washing machine rocks wildly when
my hydro heater is not wor4kin correctly its not spin/draining or washing properly
Posted on Dec 05, 2010
  • 179 Answers
SOURCE: Hi. I lost my owner
A DE Error Code is indicative of a "Door Error". This indicates that the washing machine door is not shutting, locking or opening
Posted on Jan 22, 2011
TheMobilian
  • 8220 Answers
SOURCE: whirlpool 6th sense washing machine,
Find your machines tech sheet. The error codes and suggested remedy's will be there.
Posted on Feb 01, 2011
Onida top load washing machine was HU error code coming what is problem
Hi I done a search on HU error code nothing came up call helpline 080 8856 9169 cheers
Aug 27, 2017 | Washing Machines
Defy twinmaid 800 spinner rotate very slow
Wiring diagram for a defy Twinmaid 800 washing machiine?
howtomendit.com > Household Appliances, Washing Machines Free repair help - wiring diagram defy twinmaid 800 washing machiine. ... machine spins very very slow sometimes and sometimes it doesn't spin help please.
Jul 24, 2015 | Washing Machines
Fix code error F8 in whirlpool washing machine
F8 is a board failure replace control board ( Also called ERC or clock )
Jan 15, 2014 | Whirlpool Washing Machines
Onida wash machine error code e5
what is E5 error code in onida sparkle fuzzy logic
Jan 04, 2013 | Washing Machines
Onida split ac show only f8 in display. how to slove the problem
That code is usually a result of a leak in the system and the unit being low on charge...find/fix the leak and recharge the unit.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air ConditionerTrouble -Review the Possibilities
heatman101
Jun 21, 2011 | Heating & Cooling
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
Top Washing Machines Experts
