Question about Honda Wb30x Water Pump Gx160
Wb30x Water Pump Gx140 - Honda Wb30x Water Pump Gx160
2 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: Honda water pump, wb20x/wb30x Left water in it
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
Posted on Nov 04, 2010
When trying to start a honda engine gx140 as I pull start it kicks back like a mule.??????? how to fix this problem????
Did you get the flywheel on correctly? Make sure. Compression release may be stuck? don-ohio (:^)
Nov 15, 2016 | Honda Motorcycles
Governor pivot shaft leaking oil
over filled or bad seal. or someone tilted over engine, 90 degrees. or more.
Dec 11, 2013 | Gx140 5hp Engine
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
Exhaust from pump blows on us. do you have a solution?
I can only imagine why a gas powered pump is set up so that the exhaust blows on humans and they can't move out of the way.
Anyway, look on the muffler and see if it has the exhaust deflector installed, if not, either have one made at a local muffler shop or locate one online.
for model and serial number:http://engines.honda.com/parts-and-support/serial-number-locator
for dealer:http://engines.honda.com/dealer-locator
Someone should be able to locate a new deflector for you to purchase and install. I would probably just have one made as the local muffler shops could also make extension tubes to further carry the exhaust away from where you are.
Sep 12, 2012 | Honda Wb30x Water Pump Gx160
How to replace water pump infiniti m35 2006
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
Feb 12, 2012 | 2006 Infiniti M35
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Aug 29, 2011 | 2006 Pontiac Solstice
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Nov 18, 2010 | 2001 Pontiac Aztek
Honda water pump, wb20x/wb30x Left water in it over the summer, now the start pull cord wont budge, suspect corrosion,can I fix this myself, I really need this pump next spring, only been used this 1...
Nov 03, 2010 | Honda Plumbing
Honda Wb30x Water Pump Gx160 Logo
Top Honda Plumbing Experts
Matt Olenzek
Matt Olenzek
Tony Crow
JonSnell Electronic
JonSnell Electronic
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
