Question about Electrical Supplies
Prosource model ug7500 generator parts
Rope does not turn engine when pulled
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
We sell parts for these Generators if you need any. http://www.generatorguru.com/ug7500/?sort=featured&setCurrencyId=75
Generator Guru
Posted on May 28, 2015
  • 151 Answers
SOURCE: I need to rewind a rope on pull start powermate generator
This requires a bit of strength in the hands and the recoil will have a fair amount of tension behind it. Best have a small engine service center look at. Not expensive
Posted on Dec 24, 2009
  • 5603 Answers
SOURCE: the rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Posted on Mar 24, 2010
  • 905 Answers
SOURCE: want to remove the starter recoil from my powermate generator
I got one of these pieces of junk, and had same problem you described.
You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
Posted on Jun 12, 2010
  • 1388 Answers
SOURCE: how can i convert the
Yes you can install an electric starter on your generator if the following conditions are present. Starter/fan cover has cutout for starter, the flywheel has ring gear and block has taped holes to mount starter. Examine the engine where the starter would normally be installed (look at a generator like yours with the same motor that has the starter installed ) and check that the mounting holes are there and threaded to receive the bolts. If threaded holes to mount are there and access thru starter cover to flywheel is there, check that the flywheel has a ring gear where starter motor engages. If all present starter can be installed however you will not have the charging coil which is normally under the flywheel to charge battery; but you can still use the generator to charge the battery. To locate parts, use model number of the engine not the generator. Good Luck
Posted on Oct 01, 2010
  • 1388 Answers
SOURCE: Want to add electric start
To determine if an electric starter can be installed, begin with the model number and type of engine. The engine model number (not generator number) will clue you in on the availability of accessories. In order for a starter to work on your engine, there needs to be mounting holes drilled and taped onto the back of the block to mount the starter. Also necessary is a ring gear on the flywheel and a knock-out plate on the fan cover to allow the nose of the starter into the cover. For reference, find a dealer near you that has the same type of engine with a starter already installed so that you can see the differences. Good luck of upgrading.
Posted on May 27, 2011
Putting new pull rope on my 4500 champion 4500 generator
The recoil starter can usually be unbolted from the engine for service. If you can retrieve the end of the broken rope, and you know how long the new rope should be, you can tape or stitch the new rope to the end of the old rope, then pull on the knotted end of the old rope to pull it out of the starter and draw the new one in. If this won't work (the old rope may be too rotted to hold together, or the pull force to wind the rope around in the starter is too much), you'll have to take the starter apart. This is nasty because you have to get the spring properly engaged with the frame and the starter plate when you put it back together, and there may be an element of personal hazard if there is tension on the spring. You may want to have the starter plate on the bottom when you lift off the cover, hopefully this will prevent everything from spilling out before you get a chance to see how it goes together. Wear safety glasses and leather gloves. Wearing a padded jacket or heavy-duty shop apron may also be a good idea.
Check whether the handle on the new rope requires the rope to be fed through its opening in the starter, and be sure it goes it is wound in the same direction as the original rope. Also, you want just enough tension on the spring to hold the rope handle up against the starter without flopping around, but not so much that the spring winds up too tight before you get to the stop with the rope pulled all the way out.
You may wish to take the starter unit to a small engine shop and pay them to wind on a new rope. :)
These are the considerations I've observed when looking over recoil starters - someone may have more detailed information on your model.
Finally, evaluate the storage conditions for the generator. A good rope should last a long time; perhaps excessive humidity, chemical fumes or exposure to UV radiation rotted out the rope. Did you put oil in the cylinder per the long-term storage instructions (Page 14 of the manual)? If not, that could result in excessive pull force. You may be able to free up the generator by removing the spark plug, putting a small amount of lightweight oil, turning over the generator using the starter spline shaft (be careful not to damage the shaft with tools, and observe which direction it's supposed to rotate when the recoil starter lets go), Change the oil if you have to use something lighter than recommended to get sticky parts loosened.
Here's a link for the manual (Page 14 is actually page 17 in the PDF viewer):
http://www.championpowerequipment.com/media/4663/100216_manual-english_12-10-16.pdf
Jul 15, 2017 | Electrical Supplies
Starter rope is locked. Cannot turn by pulling cord
Hi Bob:
Sounds like the engine is seized.
Try removing enough bits so you can access the flywheel and see if you can turn it. Make sure ignition is OFF.
If the flywheel does not turn it will be time for a learning experience, a trip to the maintenance shop, or a replacement.
Sep 16, 2015 | Coleman Powermate Powermate 5000W...
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
Dewalt gasoline generator ..rope does not pull
Try taking the spark plug out and see if you can turn it over.
Feb 16, 2015 | Dewalt Generator. 6000 Watt Portable...
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
Gas valve pro-source 5.5hp generator
where can I find valve prosource model # 521-400-07
Mar 02, 2013 | Electrical Supplies
I need a gas valve for a prosource 2000 watt, 5.5 hp generator
We sell them and other parts for the Generator. Shop now for parts on www.generatorguru.com/pro-source/?sort=featured&setCurrencyId=75
Mar 24, 2012 | Electrical Supplies
The rope on my generator gets stuck as i pull to turn it on
Mar 22, 2010 | Electrical Supplies
Dec 19, 2009 | Coleman Powermate Generator Start &...
Electrical Supplies Logo
161 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
