Question about Ricoh Aficio SP C811DN-DL Printer
Gestender scp 548 - Ricoh Aficio SP C811DN-DL Printer
Define the code...how to repair, estimated repair cos t
U1000 SCP (J1850) Invalid or Missing Data for Primary Id U1001 SCP (J1850) Invalid or Missing Data for Primary Id U1002 SCP (J1850) Invalid or Missing Data for Primary Id U1003 SCP (J1850) Invalid or Missing Data for Primary Id U1004 SCP (J1850) Invalid or Missing Data for EEC Programming U1005 SCP (J1850) Invalid or Missing Data for EEC Programming U1006 SCP (J1850) Invalid or Missing Data for Primary Id U1007 SCP (J1850) Invalid or Missing Data for Primary Id U1008 SCP (J1850) Invalid or Missing Data for Engine Torque U1009 SCP (J1850) Invalid or Missing Data for Engine Torque U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake U1012 SCP (J1850) Invalid or Missing Data for Primary Id U1013 SCP (J1850) Invalid or Missing Data for Primary Id U1014 SCP (J1850) Invalid or Missing Data for Primary Id U1015 SCP (J1850) Invalid or Missing Data for Primary Id U1016 SCP (J1850) Invalid or Missing Data for Primary Id U1017 SCP (J1850) Invalid or Missing Data for Primary Id U1018 SCP (J1850) Invalid or Missing Data for Throttle U1019 SCP (J1850) Invalid or Missing Data for Throttle U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch U1022 SCP (J1850) Invalid or Missing Data for Primary Id U1023 SCP (J1850) Invalid or Missing Data for Primary Id U1024 SCP (J1850) Invalid or Missing Data for Primary Id U1025 SCP (J1850) Invalid or Missing Data for Primary Id U1026 SCP (J1850) Invalid or Missing Data for Engine RPM U1027 SCP (J1850) Invalid or Missing Data for Engine RPM U1028 SCP (J1850) Invalid or Missing Data for Primary Id U1029 SCP (J1850) Invalid or Missing Data for Primary Id U1030 SCP (J1850) Invalid or Missing Data for Experimental #1 U1031 SCP (J1850) Invalid or Missing Data for Experimental #1 U1032 SCP (J1850) Invalid or Missing Data for Primary Id U1033 SCP (J1850) Invalid or Missing Data for Primary Id U1034 SCP (J1850) Invalid or Missing Data for Primary Id U1035 SCP (J1850) Invalid or Missing Data for Primary Id U1036 SCP (J1850) Invalid or Missing Data for Wheels U1037 SCP (J1850) Invalid or Missing Data for Wheels U1038 SCP (J1850) Invalid or Missing Data for Primary Id U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed U1042 SCP (J1850) Invalid or Missing Data for Traction Control U1043 SCP (J1850) Invalid or Missing Data for Traction Control U1044 SCP (J1850) Invalid or Missing Data for Traction Motor U1045 SCP (J1850) Invalid or Missing Data for Traction Motor U1046 SCP (J1850) Invalid or Missing Data for Primary Id U1047 SCP (J1850) Invalid or Missing Data for Primary Id U1048 SCP (J1850) Invalid or Missing Data for Primary Id U1049 SCP (J1850) Invalid or Missing Data for Primary Id U1050 SCP (J1850) Invalid or Missing Data for Brakes
Mar 14, 2015 | 2008 Lincoln Navigator
How to get vivitar pro 548 series 1 to work on nikon d90
The TTL contacts on the Nikon are different to the Vivitar.
You can put a remote flash trigger in the Vivitar and use the Nikon's built-in flash to trigger the Vivitar flash using the remote flash trigger.
Aug 15, 2012 | Vivitar PRO-548 Series 1 Digital TTL Shoe...
Sanyo scp-7050 unlock code
You can Unlock SANYO SCP 7050 easily using the unlock code from here Simpleunlocking.com/sanyo-scp-7050/rs16wp9/
Apr 18, 2012 | Sanyo SCP-7050 Cellular Phone
How to install the converter on a Euro Pro Shark serger 101-548
The converter your using is for 2 thread conversions. To use 4 threads you put in second needle
Aug 22, 2009 | Sewing Machines
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Time off by one hour
a pocket PC that still runs. wow. a blast from the past, 2000.
16 years it works ok , then today it fails?
you need to set time zones. and if you have DST , day light savings time in your unstated locations.
finding a manual on anything that old is problematic to you and most other helpers,
good luck with that.
Apr 12, 2017 | HP Jornada 548 Pocket PC
Jornada 548 won't print to IR on hp 450 mobile printer
the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Ricoh Aficio SP C811DN-DL Printer Logo
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
