Question about Acer AL1912 19" LCD Monitor
Nec LCD 1912 power light blinking green - Acer AL1912 19" LCD Monitor
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Acer AL1912 19" LCD Monitor Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
