Question about HP Designjet T1100ps Printer
Designjet t610 cant update firmware - HP Designjet T1100ps Printer
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
  • 16 Answers
SOURCE: mu HP Designjet T610 get mistake 21.13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Aug 18, 2009
SOURCE: updating firmware for HP designjet, use new or original settings?
U can always try to up grade firmware by going to www.mymusix.com
Posted on Oct 06, 2009
SOURCE: HP Designjet T610
NECESITO UNA SOLUCION PARA MI PLOTTER T610 CODIGO DE ERROR 22.1:10
Posted on Nov 14, 2009
  • 1170 Answers
SOURCE: hp designjet t610 error 01.1:10
Explanation Problem with the PrintMech PCA. Recommended action Try the following:
  1. Turn the printer off (using the power switch at the back of the printer), and disconnect the power cable. Wait 15 seconds and reconnect the power cable and turn the printer on.
  2. If the error continues, call HP for support.
Posted on Sep 24, 2010
What is firmware?
Firmware is the computer instruction code that is hardcoded onto computer chips in electronic devices to make them work. Most can be upgraded to add additional functionality to the device or make it run smoother. Short answer, its software.
Jul 10, 2014 | HP Designjet T610 InkJet Printer
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
Mar 15, 2014 | HP Designjet T610 InkJet Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
Hp dnj t610 plotter 79:04 eror
79.04 is a generic software error.
Can be caused by bad firmware.
Can be caused by bad job.
Try sending a different job to the printer.
If that works and the original job fails again, something is wrong with it.
If the new job fails, power off and on again. Resend the job. If it fails again...go to
www.hp.com. Select support and drivers. Upload the latest firmware.
This one isn't easy. Good Luck
Jul 09, 2011 | HP Designjet T610 InkJet Printer
My plotter is saying that there is an error, number 87:10 What is this, and what can i do do? Its a HP Designjet T610.
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
Mar 23, 2011 | HP Designjet T1100ps Printer
Mu HP Designjet T610 get mistake 21.13
Aug 05, 2009 | HP Designjet T610 InkJet Printer
HP Designjet T1100ps Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
