Question about Schiller Cardiovit At 1 Ecg Machine
Mains indication is coming but not switching on
How to fix error code 3501
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 14, 2016 | Konica Minolta Bizhub 501 Copier
Power indicator blinks but TV does not come on
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Toshiba TP50H60 50" Rear Projection...
Haotion 125 bad earth lights working incorrectly
intermintant loss of power to headlights clock air conditioning 2001 toyota avalon ! solution....new alternator and new battery fitted.
Oct 04, 2012 | Cars & Trucks
Main beam problems toyota rav4 1995
High beam elements burned out or defective combination switch
Sep 18, 2012 | 1996 Toyota RAV4
When baking the oven turns off and the F1 code is coming up.
HI. This F1 code, on this particular unit, will be a board level fault alert that will concern the actual touch pad or membrane switch. It may also be a strong indication of a watchdog error. Both indicators will result in the replacement of the main board or touch pad(membrane switch)
If this is a double oven build or newer style range/stove, This will be an indication of a failed power element relay(mechanical failure). Check the entire wiring harness assembly for shorts, in this case, If no shorts are found, replace the power relay board, asap.
NOTE_ For the double oven designs, you must replace the second PCB that is mounted within the structure and not the main.
Nov 29, 2010 | Jenn-Air JGS8750 Gas Kitchen Range
32'' LG TV no picture or sound
You may have lost the main controller board, but you should at least check the main power supply first for any signs of bad components such as capacitors. Also check the DC voltage reading on the connectro if they are labeled with voltage indicators.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Televison & Video
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Cruise control shows power on but will not turn.
the most common cause of this is the rotating ribbon contact for the steering wheel switches is defective, this contact ribbon is under the steering wheel and is commonly called the clock spring contact.
Apr 09, 2009 | 2002 Honda Civic
I turned on the main switch,but nothing works
main fuse is on the front panel with the blower fuse
Feb 07, 2009 | Lincoln Conveyor Oven - 1133-000-A
Schiller Cardiovit At 1 Ecg Machine Logo
48 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Jim Goldsmith
Jim Goldsmith
Are you a Schiller Medical Expert? Answer questions, earn points and help others
