Question about Oster 6678 14 Speed Blender
Soup Mate pro blade is jammed - Oster 6678 14 Speed Blender
Each time we use our Vitamix 750 to make soup we get a metallic flavour that is really unpleasant. The only time I haven't had it is when making smoothies. Has anyone any idea what's causing this?
No because there is very little metal in contact with the food other than the stainless steel blade and the stainless fitting below it neither of which should be leaching anything into the food.
Have a close look at the blade and the fitting under it for any signs of corrosion.
You should write (not an email) to the Company about this issue and maybe they have some explanation because these are expensive machines.
Jan 04, 2016 | Vitamix Blenders
I need an Instruction Booklet for my Soup Mate Pro Please help?
You can download a manual from this site.
http://www.ebooke-zz.com/soup-mate-pro-instruction/
Jun 08, 2015 | Blenders
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Soup mate pro won't start
try powering off, removing contents from the container, refill using less contents and push the contents to the bottom plate. Turn power on. If beeping stopped it will work. Another thing to try is turning the rubber gear on the base or bottom of the container slightly then put container back on the base, as before do this while power is off at the power point for safety. Regards Greg T. My mother bought one and Ive had to step in as Im the only one to make it work. Hope this helps you. I am about to go past for the 3rd time of her using this device to see if I can help do a re-heat as she made a soup and its now not playing ball again 4 her. Forced to contact the distributor of course!
Jan 09, 2014 | Oster 6678 14 Speed Blender
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
When I select an option for my soup maker it comes up with E2. What does this mean please?
Mine is doing it as well and I don't know what it means. Does anyone else? Mine is a Cooks Professional.
Oct 26, 2013 | Cook's Essentials Soup-a-chefs Electric...
Soup maker keeps beeping
I have also had a beeping problem and it was caused by overfilling. I removed some of the liquid and it worked!
Jan 13, 2013 | Cook's Essentials Soup-a-chefs Electric...
My Cuisinart soup maker keeps switching off
How you removed the bottom? Screws are so deeb and I cant see what screwdriver I have to get.
Nov 20, 2012 | Cuisinart SSB1U Soup Maker
Blades won't turn
If the problem is that the blades are jammed and you can't turn them manually, you can let it sit ( and dry out ) for a few days, or you can try adding some oil. I had the same problem and this worked. My problem now is that the blades don't reach to where the motor is turning, so even if they're not jammed the don't turn. If anyone knows and answer to this I'd appreciate it.
Jan 24, 2008 | Oster 6678 14 Speed Blender
Oster 6678 14 Speed Blender Logo
54 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
